    Temporarily disable heater thermal safeguards?
    • kenblu24undefined
      kenblu24
      I don't know how I'm supposed to change nozzles or clear clogs. If I touch a metal wrench to the heaterblock, or take the hotend out and clamp it in a vice, the thermal protection trips. How do I temporarily turn off all heater thermal runaway stuff?
      • elmoretundefined
        elmoret
        Shouldn't be doing any of that stuff with it powered anyway. Heat up, turn off the heater, do the thing, heat back up if necessary, etc.
        • T3P3Tonyundefined
          T3P3Tony administrators
          As Tim says it's a bad idea to do that while powered as you could induce a short between the heater and the thermistor/PT100 that can damage the board.
          That said you can change the time a heater will tolerate a fault by using M570:
          https://duet3d.com/wiki/G-code#M570:_Configure_heater_fault_detection
          www.duet3d.com
