    Servo / motor noises
    • BearcatTDundefined
      BearcatTD
      I've just got my D2 wifi / Ender 3 system up and running (first real print is on the bed), and I have a question about the noises that the servos or motors make. When the system first boots up, the machine is dead quite other than the hot end fan (its a Noctua so it is very quiet), but as soon as I run the home command it sounds almost like a fan noise coming from the motor(s). In my old setup i was running TMC2208 servos and they were very quiet during operation and no noise in between moves.
      Is this something that I can tune out of the system?
      Thanks
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
      • Vetiundefined
        Veti
        the duet wifi does not support stealthchop2 that the TMC2208 has.
        also read
        https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise
        zaptaundefined 1 Reply Last reply Reply Quote 0
        • zaptaundefined
          zapta @Veti
          @veti, is this related to micro-stepping?
          I experience similar noise and wonder if there is a gcode way to force a move nearest full step. E.g. when homing and when idling.
          Vetiundefined 1 Reply Last reply Reply Quote 1
          • Vetiundefined
            Veti @zapta
            @zapta said in Servo / motor noises:
            to a certain degree. but mainly because the ender 3 steppers are low current steppers.
