Head Movement button values
  • Hello,
    For some reason when I open the web control panel on my duetwifi the Z movement button values have all changed to half the values of the corresponding X and Y buttons. What could have caused this?
    X= 100
    Y =100
    Z = 50
  • Don't know if this is the reason but if you go to Settings, then under the User Interface tab in the bottom left pane "Machine Control" there is a check box entitled " Half Z Movements". Is it ticked? If so try unticking it. Can't test it myself because I'm in the middle of a long print.
  • That worked. Thank you.
