    motor phase A may be disconnected reported by driver(s) 0 1 2
    1727
    • fredvm
      fredvm last edited by
      Hi!
      I keep on getting this warning during calibration & print:
      Warning: motor phase A may be disconnected reported by driver(s) 0 1 2
      I have been printing for a long time without any issues and this came out of nowhere.
      I notice my prints have been shifting too. After reading up on the forum I'm thinking that my stepper driver is faulty.
      M122 returns:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-95BNL-MGPSN-6JKDJ-3SD6T-1LXVW
      Used output buffers: 3 of 20 (11 max)
      Static ram: 25632
      Dynamic ram: 93260 of which 396 recycled
      Exception stack ram used: 500
      Never used ram: 11284
      Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,356) IDLE(ready,196)
      Owned mutexes:
      Last reset 00:55:28 ago, cause: power up
      Last software reset at 2019-04-23 16:56, reason: User, spinning module GCodes, available RAM 11304 bytes (slot 0)
      Error status: 16
      Free file entries: 9
      SD card longest block write time: 339.8ms, max retries 0
      MCU temperature: min 27.2, current 40.4, max 40.5
      Supply voltage: min 11.8, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: ok, SG min/max 0/607
      Driver 1: ok, SG min/max 0/560
      Driver 2: ok, SG min/max 0/598
      Driver 3: ok, SG min/max 0/1023
      Date/time: 2019-04-24 14:21:13
      Slowest loop: 53.05ms; fastest: 0.07ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 56, FreeDm: 161, MinFreeDm: 116, MaxWait: 903214ms
      Bed compensation in use: none
      Bed probe heights: 0.213 0.010 0.226 -0.125 0.277
      === MainDDARing ===
      Scheduled moves: 37707, completed moves: 37686, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.5
      Segments left: 1, aux move: no
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G1 X3.325 Y5.336 E0.0371" in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 341.35ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.22
        WiFi MAC address a0:20:a6:2f:96:b4
        WiFi Vcc 3.34, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 26928
        WiFi IP address 192.168.0.108
        WiFi signal strength -75dBm, reconnections 0, sleep mode modem
      M913
      M913
      Motor current % of normal - X:100, Y:100, Z:100, E💯100
      M906
      M906
      Motor current (mA) - X:1000, Y:1000, Z:1000, E:1200:1200, idle factor 60%
      Can anyone please help me out or confirm the problem?
      Thank you!
      • Veti
        Veti last edited by
        check for bad crimps on the stepper cables using a multimeter.
          Have you changed the motor driver stealthChop settings recently? What M569 commands do you have in config.g?
          • Veti
            Veti last edited by
            it does not look like a duet maestro. so no stealthchop.
            • fredvm
              Thank you for your swift response!
              this is what i got:
              ; Axis and motor configuration
              M569 P4 S0 ; Drive 4 goes forwards
              I didn't change any drivers. Didn't do anything really. I've printed 50+ hours in this configuration and it popped up out of nowhere seemingly. I did do an update after the problem first started occuring.
              Yes, it's not a Duet Meastro. It's a Duet 2 Wifi ( sorry forgot to mention that ).
              I'll check for the crimping on the connectors.
                It's odd that you are getting that error on 3 separate drivers. Is it always phase A? What is the motor specification?
                • fredvm
                  The x y z motors are KL17h248-15-4A
                  Specifications:
                  Shaft: 5mm diameter with flat
                  Current Per Phase: 1.5A
                  Holding Torque: 5.5Kg.cm (76 oz-in)
                  Rated Voltage: 4.2V
                  NO.of Phase: 2
                  Step Angle: 1.8° ± 5%
                  Resistance Per Phase: 2.8Ω± 10%
                  Inductance Per Phase: 4.8mH± 20%
                  Insulation Class: Class B
                  Dielectric Strength: 100Mohm
                  Operation Temp Range: -20 ~ +40° C
                  Lead Wire: 22AWG / 750mm with connector to stepper motor driver
                  The extruder motor is 42bygh4413ag5.18-x
                  http://www.promoco-motors.com/products/StepperMotors/42BYGH Planetary Gearmotor Series.pdf
                  Thank for your assistance.
                  • fredvm
                    I'm running some test calibrations and it's not only phase A
                    G32
                    Warning: motor phase B may be disconnected reported by driver(s) 0 1
                      Do the warnings appear only when you run the motors at high speeds? What are your axis steps/mm?
                      • fredvm
                        No, i don't think so. I'm running at an avereage speed of 45 mm/s.
                        M92 X80 Y80 Z80 ; Set axis steps/mm
                        i'll put my full config.g below:
                        ; Configuration file for SeeMeCNC Rostock MAX V3
                        ; Communication and general
                        M111 S0 ; Debug off
                        M550 PSeeMeCNCRostockMAXV3 ; Machine name and Netbios name (can be anything you like)
                        M551 Retteket3t ; Machine password (used for FTP)
                        ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                        M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEA ; MAC Address
                        ;*** Wifi Networking
                        M552 S1 ; Enable WiFi
                        M555 P2 ; Set output to look like Marlin
                        M575 P1 B57600 S1 ; Comms parameters for PanelDue
                        G21 ; Work in millimeters
                        M569 P0 S1 ; Drive 0 gaxioes forwards
                        M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
                        ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
                        M665 R144.158 L291.06 B120 H392.701 X0 Y0 Z0 ; set delta radius, diagonal rod length, printable radius and homed height
                        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                        M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
                        M906 X1000 Y1000 Z1000 E1200 I60 ; Set motor currents (mA) and increase idle current to 60%
                        M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
                        M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
                        M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
                        ; Thermistors
                        M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
                        M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
                        ;M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
                        M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
                        M106 P1 H-1 ; disable thermostatic mode for fan 1
                        ; Tool definitions
                        M563 P0 D0 H1 ; Define tool 0
                        G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                        ;*** If you have a single-nozzle build, comment the next 2 lines
                        ;M563 P1 D1 H2 ; Define tool 1
                        ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
                        M92 E450:450 ; Set extruder steps per mm
                        ; Z probe and compensation definition
                        M558 P5 X0 Y0 Z1 H5 F1200 T2400
                        ; grid compensation
                        M557 R110 S15
                        G31 X0 Y0 Z-0,5 P500 ; Set the zprobe offset and threshold (determine your printer's Z offset value). For a delta, use zero X and Y offset.
                        ;*** If you are using axis compensation, put the figures in the following command
                        M556 S78 X0 Y0 Z0 ; Axis compensation here
                        M501;
                        T0 ; select first hot end
                          Phaedrux Moderator @fredvm last edited by
                          @fredvm said in motor phase A may be disconnected reported by driver(s) 0 1 2:
                          Your M350 is missing a value for Z and your M92 is missing a value for E
                          wilriker 1 Reply Last reply Reply Quote 0
                          • fredvm
                            M350
                            wow, thanks for noticing that!
                            I'll add the right values and see what happens.
                            • fredvm
                              Nope, still got the warning:
                              G32
                              • wilriker
                                wilriker Moderator @Phaedrux last edited by
                                @phaedrux said in motor phase A may be disconnected reported by driver(s) 0 1 2:
                                Just for the sake of completeness: default value for M350 is 16x interpolated (all axes) and default for M92 Ennn is 420 (X, Y=80 and Z=4000).
                                Veti 1 Reply Last reply Reply Quote 0
                                • Veti
                                  Veti @wilriker last edited by
                                  @wilriker said in motor phase A may be disconnected reported by driver(s) 0 1 2:
                                  not 400?
                                  • wilriker
                                    wilriker Moderator @Veti last edited by
                                    @veti said in motor phase A may be disconnected reported by driver(s) 0 1 2:
                                    not 400?
                                    Here's the responsible part of Configuration.h
                                    constexpr float DefaultXYDriveStepsPerUnit = 80.0;		// steps/mm
                                    constexpr float DefaultZDriveStepsPerUnit = 4000.0;
                                    constexpr float DefaultEDriveStepsPerUnit = 420.0;
                                    • Veti
                                      Veti last edited by
                                      i would say that might be an oversight. 400 is way more common than 4000. I dont even know how you would get that.
                                      • wilriker
                                        M5 threaded rod with a lead of 0.8mm. I think this was the default in Mendel printers - and Adrian Bowyer the original author of RRF is also the creator of that printer. I guess that setting stuck since. 😄
                                          Phaedrux Moderator @wilriker last edited by
                                          @wilriker Having used a printer with 0.8mm M5 threaded rod I can say that it actually worked quite well. So long as the rods were straight and the threads of the rod and nuts held out. Proper lubrication was a must. Those things would get hot during a long Z axis move.
                                            I have moved a number of posts from this thread to topic "Duet sometimes really slow? - I2C error or?".
