Duet wifi stepper noise in signal
After many months of completely unsuccessful printing with the Duet and loads of flipping back to my RAMBO, I’ve finally decided to check duet hardware for problems.
I’d first like to point of that my printer prints near perfectly whenever I swap back to my RAMBO. The Power supply is adequate, with correct voltage and current being supplied with very low vripple. The mechanical aspects of the printer are also in great shape.
Today I decided to check the steppers to see how they looked under the oscilloscope, and I was a bit shocked to see how jittery and un-square they were. I can understand why they may not be perfectly square under a load, but the jittering looks to be a stepper phase timing issue. Note that this video is with the motor powered, stationary. I did check it without the stepper, and the waves are much more squared but still jittery(lessened. I would show a video, but now the duet keeps stopping itself because it detects that the motor is disconnected. I can’t seem to bypass that safety feature anymore. On my Rambo, stepper unplugged, everything looks great. Plugged in, the signals get more rounded with slightly more noise, but way better than the duet.
Is this how all duetwifi stepper ports look? https://streamable.com/5jo00
FW:2.02
Printer: Makergear M2
the TMC drivers manipulate the wave form for noise reduction
see
https://www.trinamic.com/fileadmin/assets/Support/Appnotes/AN001-spreadCycle.pdf
So, in other-words, yours looks similar to that and its normal?
@veti said in Duet wifi stepper noise in signal:
"Hissing or chirping chopper noise can be annoying. Especially in motor standstill, many applications
are required to be silent. While the latest TRINAMIC drivers support stealthChop for absolutely silent ..."I can't wait to give it a try. It's noticeable when steppers are stationary.
Is your old Duet for sale?
@zapta said in Duet wifi stepper noise in signal:
on the duet maestro where stealthchop2 is supported at low speeds you dont even hear the movement.
on my delta the fan makes the most noise.
@Ret Can you post a picture of the bad prints the duet is producing?
config file too?
And maybe a sample of sliced gcode? Which slicer? Is it set to reprap gcode flavour?
Here is my config. Just to let you all know, I manage a print farm with custom and commercial desktop FDM printers, so I’m not anywhere near new to printing. I have them all tuned and printing very well, but they’re running marlin, repetier, and smoothie.
The big issues I’m still having is rough movement from the printer and a poor rough top layer where the extruder fills a 2-7mm section. Both of these issues (from experience) are normally related to jerk and acceleration, yet I have tried nearly every single possible combination with results not getting much better from the last test ran. I've tried tuning pressure advance and it helps, but needs a value of about 0.75 to smooth out that top layer, but trashes the rest of the print. I also get uneven extrusions, and different print results from running the same gcode right after the first. To throw in, I’ve tried S3D, Cura, slic3r, idea maker, and Pathio, all horrible results. I’ve still not gotten an answer to this post regarding the very strange jittery and noisy stepper signal. Yes, the drivers manipulate the signal, but does mine look at all similar to any of yours? To be clear, I’m not talking about audible noise, I’m referring to noise in the signal. Seems like a couple of you may have drifted from that.
About a year ago I started THIS thread. My config file has been changed since then, but results haven’t gotten much better, a year ago.
OEM setttings for marlin:
#define DEFAULT_MAX_ACCELERATION {900,1000,30,2000}
#define DEFAULT_MAX_FEEDRATE {200, 200, 25, 25}
#define DEFAULT_XYJERK 4.0
#define DEFAULT_ZJERK 0.4
#define DEFAULT_EJERK 1.0These images reflect the gcode.
1_1556294322049_simple_boat5.gcode 0_1556294322048_config.g
Here are the images:
@ret said in Duet wifi stepper noise in signal:
Makergear M2
where did you get the values for the M305 from?
From what i can see in their firmware both hed and thermistor are the same.
yet your config has different values.
also those values do not correspond to the marlin thermistor 1 values.
The bed and hotend thermistor are in fact the same model. I did try with the equivalent thermistor settings from marlin, but went further on tuning them.
I don't know about the motor signal noise. @dc42 would have to weigh in there.
From your config.g though your jerk values seem very low.
M566 X240 Y240 Z30 E120
Remember those values are mm/min not mm/s for reprap. Though it looks like you're just using the values from marlin. However, the way jerk works between the two isn't necessarily the same if I recall. Certainly not the same when it comes to the extruder and how jerk interacts with pressure advance. Not to mention how Z jerk can interact with mesh grid compensation.
Try
M566 X900 Y900 Z120 E6000
I know that for me, with X and Y jerk values that low the quick back and forth zig zag moves slow down way too much and ends up oozing a lot leading to the rough surface like in your picture.
The only good way to tell if the stepper driver is supplying the correct waveform to the stepper motors is to use a current probe in series with one of the windings. Modern stepper drivers use various techniques to reduce EMI and, achieve accurate low current microstepping, and to implement advanced features such as stealthchop.
@Phaedrux I'm aware of the units. I initially copied over the exact (converted) units from marlins FW, with no success. I've tried more duet printer standard accel and jerk like yours and it doesn't improve anything. I printed the little boat again with your exact jerk settings and it turned out worse than with the low jerk and accel. The makergear is a very solid printer, but its not designed for very high speeds, accel, and jerk. Any other suggestions?
Can you show us a comparison of two photos of prints, one showing the effects you're trying to correct and another that doesn't show these effects, ideally printed on the same printer?
The prints you have shown don't look amazing, but they don't look bad. I would hesitate to implicate anything other than different settings exciting mechanical errors in different ways.
@bot I ran out of white, but this is the same sliced settings, printed on my rambo, just modified the jerk and acceleration gcode commands and format. You can clearly see the difference between the two, and that's not even using my normal RAMBO slicing settings, that's using the settings that work the best on the duet, but are still not good.
That was printed on the exact same printer? I do see a difference, and it seems related to the extruder axis IMO. Would you agree?
Can you post the accel, jerk, and speed settings you are using in marlin, and then post what settings you used on the duet? Please include the values for the extruder axis.
How confident are you in the accuracy of your thermistor values?
M305 P1 T100000 B4138 C0 R4700
The white one does look kind of over extruded, but that could also be from printing too hot?
@bot yes, same printer. I copied the exact same values used in the gcode I posed, just converted them from reprap firmware to marlin, and converted the units where needed. At this point im not quite sure what to think. If i was trying to debug someone else having this issues, id probably agree with you about extruder, but from my perspective, it doesn't make sense at all. Reducing flow on the duet only minimizes the problem proportionally and ruins the rest of the part, so it seems its not flow.
@Phaedrux ---I'm pretty confident in the accuracy since its what I used in marlin as well for a little bit. To be honest, I made the changes long ago and reverted them back to defaults and see no difference in quality at all. PLA has such a wide range of printing temperatures that it must have just been okay.
[...] I copied the exact same values used in the gcode I posed, just converted them from reprap firmware to marlin, and converted the units where needed. [...]
Jerk does not work the same way as in marlin, afaik. IIRC, you essentially have to use half the jerk value in RRF than you do in marlin. This is because, and my memory might be failing me here, marlin uses half the jerk value as the start/stop speed, and the jerk value itself is used for cornering speeds or something.
Anyway, it's obvious that copying and pasting the settings isn't working, so you should start trying different values to see what changes things.
Is there a Makergear user group somewhere that you could check in with and see if others are having similar issues using the Duet?
@bot I'm aware its different, just not by what degree. Please re-read my post as ive not just copied and pasted and started asking for help. I've gone through many many many different configurations with the jerk and accel from really low to super high with no significant quality improvements. Please don't get me wrong here, i do appreciate everyones help on this, i'm just very frustrated with this issue. If i in fact need to reduce my jerk by half, ill be running at around X120 Y120 Z15 E30 which in my opinion, as of what everyone else settings are, is on the very low end of things. I have in fact tried half of my original settings from marlin with very very jerky slow prints, which makes sense.
@Phaedrux I've sent messages out to a few people who've put the duet on their printer and their settings near match mine and the marlins default values. They both say they love their duet, which makes me wonder if I've either got a faulty board, or am having unrealistic expectations for the duet.
Are you positive that your maximum speeds and accelerations are the same as for marlin? Or maybe marlin doesn't coordinate the E axis well with the X/Y/Z axes, and so you have to increase your accel/jerk for the E extruder a lot, without adjusting the X/Y values.
If you want, I'll lend you a Duet WiFi to see if you have a faulty board. Just pay for postage and promise to send it back.
