    Warning: motor phase A may be disconnected reported by driver(s)
    1133
    • supernovae
      supernovae last edited by supernovae
      Getting these warnings while running my homing
      6:48:33 PMWarning: motor phase A may be disconnected reported by driver(s) 4
      Warning: motor phase B may be disconnected reported by driver(s) 4
      6:48:19 PMWarning: motor phase A may be disconnected reported by driver(s) 4
      6:46:39 PMWarning: motor phase A may be disconnected reported by driver(s) 4
      6:46:22 PMWarning: motor phase A may be disconnected reported by driver(s) 4
      6:46:15 PMWarning: motor phase A may be disconnected reported by driver(s) 4
      Nothing seems to be failing, just flashing all over my screen
      Hypercube Evolution 300x300x400 dual zed
      (moved complete config to reply below, as i had my config mirrored and corrected that for another issue but still see these warnings all the time during homing/movement)
      sometimes #2 motor does it as well - #2 and #4 i believe are my Z motors.
      Diagnostics isn't showing much warning
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917DA-G4MSJ-6JTD6-3SN6L-1TRR9
      Used output buffers: 1 of 20 (17 max)
      Static ram: 25524
      Dynamic ram: 98596 of which 0 recycled
      Exception stack ram used: 512
      Never used ram: 6440
      Tasks: NETWORK(ready,648) HEAT(blocked,1232) MAIN(running,3844) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:03:52 ago, cause: software
      Last software reset at 2019-04-30 18:27, reason: User, spinning module GCodes, available RAM 6520 bytes (slot 1)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 33.0, current 33.3, max 33.6
      Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/833
      Driver 1: standstill, SG min/max 16/855
      Date/time: 2019-04-30 18:31:24
      Cache data hit count 866051605
      Slowest loop: 3.22ms; fastest: 0.08ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 238, MaxWait: 156687ms, Underruns: 0, 0
      Scheduled moves: 16, completed moves: 16
      Bed compensation in use: none
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 202.49ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        Failed messages: pending 0, notready 0, noresp 1
        WiFi firmware version 1.22
        WiFi MAC address 80:7d:3a:3f:f3:25
        WiFi Vcc 3.41, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 28032
        WiFi IP address 192.168.50.56
        WiFi signal strength -68dBm, reconnections 0, sleep mode modem
      • Veti
        Veti last edited by
        have you checked the crimping work with a multimeter?
        supernovae 1 Reply Last reply Reply Quote 0
          Please post your complete config.g file and your homing files.
          • supernovae
            ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 30 2018 17:18:07 GMT-0700 (Mountain Standard Time)
            M667 S1 ; Select CoreXY mode
            M550 P"HEVO" ; Set machine name
            M551 P"noway" ; Set password
            M552 S1 ; Enable network
            M587 S"not" P"real" ; Configure access point. You can delete this line once connected
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M569 P0 S1 ; Drive 0 goes backwards
            M569 P2 S1 ; Drive 2 goes backwards
            M569 P4 S1 ; Drive 4 goes backwards
            M584 X0 Y1 Z2:4 E3 ; Drive 0 controls X, Drive 1 controls Y, Drive 2:4 controls Z, Drive 3 controls E
            ; Motor order: Left (1), Right (2)
            M671 X-35:335 Y150:150 S3 ; Location of the Lead Screws
            M92 X80 Y80 Z400 E804 ; Set steps per mm
            M566 X600.00 Y600.00 Z120.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
            M203 X12000.00 Y12000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z20.00 E550.00 ; Set accelerations (mm/s^2)
            M906 X1000.00 Y1000.00 Z1400.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S50 ; Set idle timeout
            M208 X5 Y5 Z0 S1 ; Set axis minima
            M208 X285 Y295 Z390 S0 ; Set axis maxima
            M574 X1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (X-MIN(1)) (S3=SENSORLESS)
            M574 Y1 S1 ; Set active High endstops (S1=SENSORED) (Y-MIN(1)) (S3=SENSORLESS)
            M574 X1 S3 ; Set endstops controlled by motor load detection
            M574 Z1 S2 ; Use zprobe and home to min
            M915 X Y S7 R0 F0 ; set X and Y to sensitivity 7, do nothing when stall, unfiltered
            M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
            M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
            G31 P25 X-24 Y-19 Z0.27 ; Set Z probe trigger value, offset and trigger height
            M557 X25:250 Y25:250 S75:75 ; Define mesh grid
            ;M140 H-1 ; Disable heated bed
            M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
            M106 P0 S1 I0 F500 H1 T30 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P0 T45 H1
            M106 P1 S1 I0 F500 H1 T30 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M563 P0 D0 H1 ; Define tool 0
            -- homeall
            ; homeall.g
            ; called to home all axes
            ; Home Y First
            M400 ; make sure everything has stopped before we make changes
            M913 X55 Y55 ; reduce motor current to 55% to prevent belts slipping
            G91 ; relative positioning
            G1 Z10 F4800 S2 ; lift Z relative to current position
            G4 P500 ; wait 500msec
            M400
            G1 S1 Y-430 F4800 ; move quickly to X or Y endstop and stop there (first pass)
            M400
            G1 Y10 ; Move Away 10mm X axis
            M400
            ;G1 Z-5 F6000 S2 ; lift Z relative to current position
            ;G90 ; absolute positioning
            ;M400 ; make sure everything has stopped before we reset the motor currents
            ;M913 X100 Y100 ; motor currents back to normal
            ; Home X Second
            G1 S1 X-305 F4800 ; move quickly to X or Y endstop and stop there (first pass)
            M400
            G1 X10 ; Move Away 10mm X axis
            M913 X100 Y100 Z100 ; motor currents back to normal
            ;Home Z Last
            G1 X150 Y150 F6400 ; go to first probe point
            M400
            ; homex.g
            ; called to home the X axis
            M913 X45 Y45 ; reduce motor current to 45% to prevent belts slipping
            M400
            M400
            M400
            G1 Z-10 F6000 S2 ; lift Z relative to current position
            ; homex.g
            M400
            M400
            M400
            ; homez.g
            ; called to home the Z axis
            ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 30 2018 17:18:08 GMT-0700 (Mountain Standard Time)
            G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.
            ;G91 ; relative positioning
            ;G1 S2 Z5 F100 ; lift Z relative to current position
            • supernovae
              supernovae @Veti last edited by
              @veti going to check this now, that was recommended by someone on facebook
                I don't see anything in your config.g or homing files that would explain the problem, but you have a higher Z motor current than X and Y. What is the specification of your Z motors?
                • supernovae
                  1.7 A/phase 82gcm2 1.8hms 3.06v from Zyltech. I'll drop the ma down to match the rest and see if that helps.
                  I disconnected the Z rods and did flags on them to make sure i wasn't missing anything obvious and they spin the right way (but 4 still complains)
                  When you have dual z - does #2 and #4 match any of the pins on the duet specifically? like is it the top or bottom pins or right or left motor by convention?
                  • supernovae
                    i printed benchy and i don't see this error while printing - only before and after. I have a different nema 17 I'll experiment with and see if a potential wiring problem is internal to motor. i recrimped ends to make sure it wasnt the plug directly to duet
                    • Cata
                      Cata last edited by
                      Same problem here. 2 nema 17 in series, duet maestro, 12v, with all the currents, speeds and firmware versions.
                      Warning: motor phase A may be disconnected reported by driver(s) 2 going UP
                      Warning: motor phase B may be disconnected reported by driver(s) 4 going DOWN
                      Only stops whe using M569 P2 V670 or bigger value. But the motors are too noise to keep that value.
                      dc42 2 Replies Last reply Reply Quote 0
                        dc42 administrators @Cata last edited by dc42
                        @cata said in Warning: motor phase A may be disconnected reported by driver(s):
                        I guess that stealthChop is interfering with the open-load detection then. Can you confirm that you are running firmware 2.02 or later? Do you have the specification of the motors? If they are low-current motors then to keep them quiet, you may need to connect them in parallel instead of in series, or connect them to separate stepper drivers.
                        Cata supernovae 2 Replies Last reply Reply Quote 0
                        • Cata
                          Cata @dc42 last edited by
                          @dc42 tested in all 2.03 betas and 2.02 stable.
                          Motors are low current, no data of the model or manofacturer.
                          Connected in parallel today, same warning with some "largue movements", 25 - 50 mm in one command.
                          Cant use another driver, dual extruder is setted
                          Veti 1 Reply Last reply Reply Quote 0
                          • Veti
                            Veti @Cata last edited by
                            @cata
                            try reducing the maximum speed of the z axis.
                            Cata 1 Reply Last reply Reply Quote 0
                            • supernovae
                              supernovae @dc42 last edited by
                              @dc42 I am running latest firmware when i get this warning - only on faster movements. WHile printing i'm not seeing it.
                              • Cata
                                Cata @Veti last edited by
                                @veti from 360 to 180 and now dont see the warning.
                                Then i cant use motors in series? Whats the point of the warning if my motors works well?
                                • Veti
                                  Veti last edited by
                                  stealthchop2 has drastically reduced torque on 12v. you will need to upgrade to 24v.
                                  there is an extensive video about it. https://www.youtube.com/watch?v=GVs2d-TOims
                                  • supernovae
                                    I'm already 24v
                                      Driver 4 is the E1 motor output. What do you have connected to that output?
                                      When you connected the motors in parallel instead of in series, were you able to use a larger M569 P2 V parameter without the motors becoming too noisy?
                                      Cata 1 Reply Last reply Reply Quote 1
                                      • Cata
                                        @dc42 said in Warning: motor phase A may be disconnected reported by driver(s):
                                        Mistiping, both warnings are for driver 2
                                        No, same noise
                                          I've changed the code in firmware 2.03RC1 to disable the open load detection when in stealthChop mode. I expect to release that version later today or tomorrow.
                                          • Cata
                                            @dc42 Thanks, i dont run for this but prefer to avoid the warning flood.
                                            I will test again the conbinations when release the new firm.
