    IR Probe Z-Offset to big???
    IR Height Sensor
    551
    • CR3D
      CR3D last edited by
      Hello Friends,
      since a few days I use a IR Probe (from DC42).
      I calibrated it like the description here:
      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
      I attached my config settings:
      The problem is, my Z-Probe offset is about 11mm. Normally it should be 1-2mm I think. But the probe triggers at these distance.
      Through this big distance I have measurement errors for each prints...
      New IR Probes will arrive in a few days, then i can test other Probes...
      Any sugestions here?
      Thank you a lot!!!
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      • aidar
        aidar last edited by
        Hi. Cant see your config, but 1-2 mm should be Z height, it is distants from nozzle to bed at the moment when probe triggers. So, if you probe triggers, when it is 11 mm from bed, then you should move it up from nozzle, let say 10 mm, so when probe triggers, your nozzle will be about 1 mm from bed. I hope my bad english makes sense...
        • CR3D
          CR3D last edited by
          Yes I made this,... but then after restart the printer... the probe triggers at 11mm again...
          Here are the settings...
          Homepage:
          www.cr-3d.de
          Facebook:
          Our Discord Server
          Stephen6309 1 Reply Last reply Reply Quote 0
          • aidar
            Sounds like you didnt calibrate your Z height properly. Did you follow exactly this: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height ? Especially this in point 7 : Send command G30 S-1. People often forget to add that S-1 and sending S1 instead.
            CR3D 1 Reply Last reply Reply Quote 0
            • Stephen6309
              Stephen6309 @CR3D last edited by
              @cr3d You set the Z offset to 11.38, so it would trigger at 11mm.
              • CR3D
                CR3D @aidar last edited by
                @aidar
                Yes I made exactly this (the probe height was about 2mm)... it worked for a time ...but after a restart (unplug) the Probe triggers wide away from the bed.
                So i set the trigger height to this high value...now it works, but I have big errors between each print....
                Homepage:
                www.cr-3d.de
                Facebook:
                Our Discord Server
                • CR3D
                  CR3D @Stephen6309 last edited by
                  @stephen6309
                  It always triggered at this height... if I set the value to about 2mm then i print about 10mm in the air... 😞
                  Homepage:
                  www.cr-3d.de
                  Facebook:
                  Our Discord Server
                    If it's triggering (and the red led illuminating, not flashing rapidly) 11mm above the bed, please ask your supplier to replace the sensor. A small number of sensors have this issue with some bed surfaces. I made a firmware change a few weeks ago to address it.
                    • CR3D
                      CR3D @dc42 last edited by
                      @dc42 Thank you!!!
                      I have already doubted myself! 😄
                      Homepage:
                      www.cr-3d.de
                      Facebook:
                      Our Discord Server
                      • CR3D
                        CR3D last edited by
                        Ok... i want to report the results...
                        After I changed the IR Probe... the error was gone .. 🙂
                        Thank you dc42!
                        Sometimes there is a little error between the measurements... I think I should slow down the speeds...
                        Homepage:
                        www.cr-3d.de
                        Facebook:
                        Our Discord Server
