    Worst day for my Duet Wifi
    1.0k
    • Rinaundefined
      Rina
      I connected the end stops for test. X and Y are switches and Z is optical Lerdge. alt text
      When turned on, only some diodes glowed (VIN, 5V+). Wifi was not glowing. I was scared that I had connected the optical sensor incorrectly, turned off the Duet, rechecked the connection, but everything was right. Then I disconnect the VCC line from sensor. The Duet started. The sensor did not work.
      Then I connected to the sensor 5V from the expansion (#1 +5V). The Duet turned on, the sensor was determined. At the moment of the optical sensor was closed, element U3 began to smoke. I immediately turned off the Duet.
      I have two questions. What did I do wrong and what can I do?
      Thank you!
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @Rina
        @rina I have only found one thread https://forum.duet3d.com/topic/6462/u3-burned-a-hole-in-itself/6 about burned U3, where the reason was probably a short circuit.
        Rinaundefined 1 Reply Last reply Reply Quote 1
        • A Former User?
          A Former User
          There has been speculation of a bad batch of those U3 regulators. If you convince the devs here you didn't wire it wrong they might authorize a warranty replacement.
          But I guess it also depends on when/where it was purchased. If you can't get the board replaced you might be able to buy a 5v supply and connect that to take over from U3. (Or a dc/dc converter to make up 5v from the existing power supply).
          • Rinaundefined
            Rina @JoergS5
            @joergs5 Thank you for the link! I checked the diode D2, it seems it is damaged.
              I am sorry that your Duet WiFi had failed. Please ask your supplier to replace the board. I am automatically approving warranty replacements in cases of U3 failing.
              • Rinaundefined
                Rina @dc42
                @dc42 Thanks for the answer! I ordered a Duet in Filastruder with delivery to Russia. Do I need to send a card to Filastruder? Can I contact you in private messages?
                  dc42 administrators @Rina
                  @rina, you will need to email Filastruder.
                  • Rinaundefined
                    Rina
                    Thanks to Duet3D for the replacement!
                    Recently completed all connections and here are the results of the first print.
                    Not good, but I am very happy with this result.
