    Downward fan won't start turning on its own
    • Andy Cohen
      Andy Cohen last edited by
      If I set my downward fan to less then around 50% in my slicer in the gcode to start at the 2nd layer, it needs to be turned by hand to get it to start. Do I need a new fan or can I tweak the PWM freq???
      • Scachi
        Scachi last edited by
        There is a setting to configure a fan to run at startup at 100% for some time to get those fans running first and then set it to the requested speed:
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
        Extra Parameters :
        Bnnn Blip time - fan will be run at full PWM for this number of seconds when started from standstill. Default is B0.1.
        Try a longer time than 0.1 to test if that helps.
          Blip should help but you can also test other frequencies. Some fans don't seem to like to start with high frequency settings.
          Andy Cohen 1 Reply Last reply Reply Quote 0
          • Andy Cohen
            Andy Cohen @Phaedrux last edited by
            @phaedrux Thx to both replies!
