    Duet Wifi - G29 causes extremely rapid Z movement and head crash
    702
    • lowracer
      lowracer last edited by
      I'm running an Ultimaker 2+ upgraded to Duet Wifi and BLtouch Classic. G29 soon after install of the Duet board worked correctly and generated a heightmap which I've been using for some months now. Generated lots of good prints with no issues.
      Recently, I decided to generate a new heightmap, but upon sending G29, this causes the bed to rise at a lightning fast pace until it impacts the hotend, at which point I feel compelled to do an Emergency Stop.
      Any ideas what could be going on?
      M115 reports: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
      • Veti
        Veti last edited by
        post all your config files.
        • lowracer
          Here is config.g: https://pastebin.com/p3RDx132
          • Veti
            Veti last edited by
            M203 X18000 Y18000 Z9000 E6000 ; Set maximum speeds (mm/min)
            you z speed is 150mm/s. that is a lot
            try something reasonable like 6-10mm/sec (360-600)
              M558 P9 H5 F1200
              Your probing speed is an order of magnitude faster than it should be for the BLTouch. Try F120 instead. This is in addition to the change Veti has suggested.
              • lowracer
                Thanks for the tips. I re-tried the G29 with the speed and probing settings suggested. Now it goes slowly enough that I can see more detail of what is happening.
                During the slow rising of the bed, the BLTouch lights up red and is not extending its metal probe as it usually does at the beginning of a print.
                Also, simultaneously with the Z axis motion, the Y axis is moving ever so slowly to the left.
                  Does the probe work if you go through this procedure?
                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                  • lowracer
                    Those linked tests work, M401 & M402 behave as expected, G30 properly extends the probe, raises the bed slowly and detects the bed with the probe, then stops.
                    To clarify, this printer is working and has been working very well to make prints, always using BLTouch probe before printing. It's just that the G29 is behaving oddly. And it hasn't always been this way because I'm using G29 S1 in the startup GCODE of each print to load up a heightmap generated from a previous G29 some time ago.
                      Phaedrux Moderator @lowracer last edited by
                      @lowracer said in Duet Wifi - G29 causes extremely rapid Z movement and head crash:
                      That is very odd behaviour and I can' explain why it would be doing that, but then homing fine.
                      • lowracer
                        I'm suspecting something scrozzled the firmware. Will try re-flashing new firmware tonight to see if that fixes it.
                        • lowracer
                          Reflashing firmware did not fix the problem, unfortunately.
                            Can you post a video of it in action?
                            • lowracer
                              Here's a dropbox link to the video of the G29 operation in action (7.78MB .mp4):
                              https://www.dropbox.com/s/u8qfz1u7khgt8f5/G29 UM2%2B Duet Wifi.mp4?dl=0
                              • Veti
                                Veti last edited by
                                please post all your homing scripts.
                                • lowracer
                                  Flashed firmware up to 2.03RC1, G29 still exhibits the same behavior. Here are the homing files as requested:
                                  ; homex.g
                                  ; called to home the X axis
                                  ; generated by RepRapFirmware Configuration Tool on Fri Mar 15 2019 21:53:32 GMT-0700 (Pacific Daylight Time)
                                  G91 ; relative positioning
                                  ;G1 Z5 F6000 S2 ; lift Z relative to current position
                                  G1 S1 X-228 F9200 ; move quickly to X axis endstop and stop there (first pass)
                                  G1 X5 F6000 ; go back a few mm
                                  G1 S1 X-228 F360 ; move slowly to X axis endstop once more (second pass)
                                  ;G1 Z-5 F6000 S2 ; lower Z again
                                  G90 ; absolute positioning
                                  ; homey.g
                                  ; called to home the Y axis
                                  ; generated by RepRapFirmware Configuration Tool on Fri Mar 15 2019 21:53:29 GMT-0700 (Pacific Daylight Time)
                                  G1 S1 Y228 F9200 ; move quickly to Y axis endstop and stop there (first pass)
                                  G1 Y-5 F6000 ; go back a few mm
                                  G1 S1 Y228 F360 ; move slowly to Y axis endstop once more (second pass)
                                  ;homez.g
                                  G91 ; relative mode
                                  G1 S1 Z210 F7000 ; move Z towards the switch until it triggers
                                  ;G1 S2 Z-5 F100 ; move Z back 5mm
                                  ;G1 S1 Z10 F100 ; move Z slowly towards the switch until it triggers
                                  G90 ; back to absolute mode
                                  ; homeall.g
                                  ; called to home all axes
                                  ;home Z to max extent (bottom of enclosure) first
                                  G91 ; relative mode
                                  G1 S1 Z250 F7000 ; move Z towards the switch until it triggers
                                  G1 S1 X-228 Y228 F9000 ; move quickly to X and Y axis endstops and stop there (first pass) (was F1800)
                                  G1 X5 Y-5 F7200 ; go back a few mm
                                  G1 S1 X-228 Y228 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                  G1 X110 Y110 F7200 ; go to first probe point (approx center of bed)
                                  ;G30 ; home Z by probing the bed
                                  ;G91 ; relative positioning
                                  ;G1 S2 Z5 F100 ; lift Z relative to current position
                                  ;G90 ; absolute positioning
                                  • Veti
                                    Veti last edited by
                                    you move your bed up by 250mm? why
                                    you disabled your probing of the bed. so no wonder the probe is not deploying.
                                    lowracer 1 Reply Last reply Reply Quote 1
                                    • lowracer
                                      lowracer @Veti last edited by
                                      @veti said in Duet Wifi - G29 causes extremely rapid Z movement and head crash:
                                      Thanks for the response.
                                      Original Ultimaker 2+ (UM2+) behavior (no BLTouch) has the bed "zero" to the bottom of the case before printing and after print is completed. Moving it 250 sends down it to where it will trip the Z endstop at the bottom of the cage.
                                      The problem described in the original post occurs when issuing a G29 command from the web interface. I was not aware these homing scripts get called by the G29 command.
                                      I commented out that G30 because I do not want "homing" behavior to include probing the bed. I have that done in the startup script in the GCODE of the file being printed, e.g.:
                                      G28 XY ;Home XY
                                      M561 ; Clear any bed transform that might be in place
                                      G1 X104.5 Y130 ; Move Probe to middle of bed
                                      G30 ; Do a single probe
                                      G29 S1; load heightmap
                                      G1 Z20.0 F6000 ; Move Z to 20
                                        So before you run G29 it needs to accurately know where Z0 is. If you are homing to Zmax, how confident are you that When you move the bed back up Z0 will mean the nozzle is touching the bed? Are you running a G30 before doing G29?
                                        • lowracer
                                          lowracer @Phaedrux last edited by lowracer
                                          @phaedrux said in Duet Wifi - G29 causes extremely rapid Z movement and head crash:
                                          Bingo. That fixed it.
                                          Thanks for the help. Got a new heightmap generated and printing away.
