    Power third party board with duet usb
    Third-party add-ons
    453
    • Fdem
      Fdem last edited by
      I want to make a board for use an MPG.
      This board will send gcode via usb and have to be powered.
      Can i use duet 2 usb to power it ?
      Sorry for my bad english 🙂
        A USB Device such as the Duet can't provide power through the USB cable. Only a USB Host can do that. So you would need to run separate 5V power and ground wires from the Duet to your other device.
        • Fdem
          Fdem last edited by
          thank you for your reply
          I thought, so I'll add a 5V power supply on my board
          • Veti
            Veti last edited by Veti
            the duet cant supply power through the usb. however it can supply 5v via the fan header if it is set to 5v or the expansion slot
              dc42 administrators @Veti last edited by
              @veti said in Power third party board with duet usb:
              Or from the PanelDue port, if you are not otherwise using it.
              • Fdem
                Fdem last edited by
                Thanks, i will use 5v fan
                • Cata
                  Cata last edited by
                  Why not connect the boad direct to the paneldue port?
                  • Fdem
                    Fdem last edited by Fdem
                    Because i have an paneldue already connected
                    • Fdem
                      Fdem last edited by
                      my personal card is now finished
                      is there a way to visualize what my duet 2 recipes by usb port?
