panel due 7i issue
Hi everyone
I'm having some problems with mi paneldue i7, any button that i touch on the touch screen, is like if i push the emergency stop button... In the right corner on the top of the screen came out "connecting" for a couple seconds an after that came out "idle "
Some body can tell me what should i do?
Thanks
Are you using the ribbon cable, or the 4-way cable? If it's the 4-way cable, check that the wiring is connect. The order of the wire colours should be reversed from one end of the cable to the other.
After this has happened, run M122 on Duet Web Control or from USB, and look at the reset data to see whether the Duet really did restart.
thi is the report :
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet Ethernet 1.02 or later
Board ID: 08DGM-9T6BU-FG3S0-7JTD8-3SJ6S-KB6VH
Used output buffers: 3 of 20 (14 max)
Static ram: 28380
Dynamic ram: 95888 of which 0 recycled
Exception stack ram used: 428
Never used ram: 6376
Task NETWORK ready, free stack 324
Task HEAT blocked, free stack 800
Task MAIN running, free stack 3612
Last reset 04:12:16 ago, cause: software
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6524 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 7.0ms
MCU temperature: min 29.7, current 32.3, max 34.5
Supply voltage: min 22.9, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0
Driver 0: standstill, SG min/max 0/0
Driver 1: standstill, SG min/max 0/0
Driver 2: standstill, SG min/max 0/0
Driver 3: standstill, SG min/max 0/1023
Driver 4: standstill, SG min/max 0/176
Date/time: 2019-05-15 16:49:34
Slowest loop: 78.08ms; fastest: 0.07ms
Hiccups: 3312, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 121, MaxWait: 2370385445ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: mesh
Heater 0 is on, I-accum = 0.2
Heater 1 is on, I-accum = 0.5
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 54.89ms; fastest: 0.01ms
HTTP sessions: 1 of 8
Interface state: 5
=== Filament sensors ===
Extruder 0 sensor: ok
=== Expansion ===What it means?
@dc42 i'm using the 4 way cable, it was working ok, yesterday i change the case and after that the issue came out
Remove the case and try again?
Also check that you have the baud rates of PanelDue and the Duet set the same (57600 baud). PanelDue sends a special message to the Duet when emergency stop is pressed, and it's just possible that a particular normal message at the wrong baud rate could be misinterpreted as emergency stop.
@dc42 where should i check that parameter? at the moment i can't go inside in the set up window in the paneldue
@jv said in panel due 7i issue:
Disconnect the PanelDue from the Duet and power it from a USB cable instead. Alternatively, leave it connected but hold the Reset button on the Duet down while you enter the Setup page.
Hello guys, thankyou very much for your help, i solved the problem.
The new case was pushing a little in the side of the touch panel, i put a little spacer and the touch panel now is working.
I really aprecciate your help and the time that you take for give me your advice.
I wish you a great day
