Sanity Check Plz!!! Omron Inductive switch for XYZ endstops
This is for a mill so no Z probing. I can get 3 of these dirt cheap https://www.ia.omron.com/product/item/1017/
and would like to use them on a new mill build. Here's my board info...
I see info here https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mode_Num_5
on how to connect as a Z probe but how do I hook them up for XYZ endstops?
Thanks -
if you have a duet v1.04 you connect them like a npn probe
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
but instead of connecting the signal wire to the z probe port you connect the signal wire to the stop pin for xyz -
Thanks for holding my hand on that one Veti. I have board v1.02 so I'll add in the diodes as well.
That looks OK to me.
Thank you Sir.
Results are good. This switch repeats within .002 mm and that's probably in the mechanics. Perfect for milling application
