Uneven layers
The bulges match the pitch. The lead screws are 2mm pitch 2 start. There are 2 screws and 2 motors connected one to each connector on the duet. I will have to dig up the model of the motors but I know for sure they are 1.8 degree 40Ncm.
16th steps no interpolation. spiral shell at .2mm
awe man... i hate to admit my issue was mechanical after all... I must have knocked one of the z leads off center doing the board install. I stripped the z axis down, clean, lubed and the next print was flawless. hopefully @Haggan90 your problem is as simple as an alignment issue as well.
@antlestxp Thanks so much for coming on and letting us know the cause!
@antlestxp I'm super glad it worked out for you!
I've abandoned my lead screws and aiming for a belt driven Z axis instead.. doesent matter what I do, I still get this imperfections. -
@haggan90 I'm gonna try a belt driven screw before I revert belt only. The 2mm pitch screw will prevent the bed moving, a belt only would need a worm gear to hold the bed in place in case of power loss. Maybe something to consider, can print most of the parts although I'm going all metal, with a bearing block to provide both radial and axial support for the screw, but that means I also have to redesign the x-axis (then again wanting to use openbuilds style anti backlash nuts (flat/square type) so would have had to do that anyway)
@haggan90 said in Uneven layers:
It might not be the lead screw of the belt. it could be friction because of the linear bearings.
your SCSXUU might be to short to give a stable bed try some SCSXLUU. -
@bearer that's awsome! I habe a system with a 3:1 gear ratio in mind with a 10mm belt. As I use 3 individual motors for the Z axis I don't think the bed will "fall" down during a powerloss, maybe it will slowly glide down
@veti if I use the longer bearings there is a chance of binding when I level the bed, as I use 3 motors for leveling. I've measured that the bed moves a maximum of +-0.02mm in X/Y during movement in Z.
@haggan90 I would think that you'd want the flex point to be between the rigid bearing and the bed plate rather than the bearing itself.
@phaedrux it's not possible in my design atm. Best case scenario would be if I used linear bearings for the z axis as well, then i could have all 3 points move more independent.
@haggan90 Perhaps consider using oldham style couplings to mount your screws to the bed to allow for some self alignment.
https://www.thingiverse.com/thing:2907060
