    Delta does not home all axis when finished in extreme Position
    • ProntoPrintundefined
      ProntoPrint
      Hello
      I have a minor problem on my TLM Delta with duet wifi.
      If the effector stopped in a extreme position (most front D340) it homes but only on the axe with the most high position. the other two stop about 10 cm away on the first and the seccond pass .
      If I push home twice all axis are homed correctly.
      Can somebody tell me which parameters have to be modified that all axis are homed correctly during the first home
      Thanks
      • Danalundefined
        Danal
        Your /sys/homedelta.g will look something like this:
        ; homedelta.g
        ; generated by RepRapFirmware Configuration Tool on Fri Jan 12 2018 20:07:04 GMT-0600 (Central Standard Time)
        G91                        ; relative positioning
        G1 S1 X955 Y955 Z955 F1800 ; move all towers to the high end stopping at the endstops (first pass)
        G1 X-5 Y-5 Z-5 F1800 S2    ; go down a few mm
        G1 S1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
        G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
        G90                        ; absolute positioning
        G1 X0 Y0 F6000
        Increase the bold numbers:
        Note: This is from a large-ish delta, over 1.5 meters tall, so the existing numbers in bold above are very near a meter... yours will be smaller.
          This is covered in the FAQ page in the Troubleshooting section.
          ProntoPrintundefined 1 Reply Last reply Reply Quote 0
            ProntoPrint
            superb, this did the trick!
            as you said I got aware that in extreme positions the one arm could be way more thant the maxiimum delta hight at all
            so I modified homedelta.g to
            For all TevoLittle Monster owners this worked for me:
            G1 S1 X630 Y630 Z630 F1800
            Original it was set to G1 S1 X510 Y510 Z510 F1800 for the TevoLittelMonster
            This caused the issue!
            Thanks a lot1_1558803118252_IMG_20190525_184837.jpg 0_1558803118252_IMG_20190525_184855.jpg
              ProntoPrint @dc42
              @dc42 thanks a lot but I have searched for a solution for 2 hours before I wrote the Topic
              Please if there is a FAQ Topic already "provide a link",
              still cannot find it.
              Thank you very much in advance!
              • T3P3Tonyundefined
                T3P3Tony administrators @ProntoPrint
                @prontoprint https://duet3d.dozuki.com/Wiki/FAQ#Section_When_I_try_to_home_my_printer_sometimes_the_carriage_or_carriages_move_only_part_of_the_way_towards_the_homing_switches_and_I_have_to_command_it_to_home_again_to_make_it_go_all_the_way
                www.duet3d.com
