Slicer questions on Ender 3 / Duet 2 Wifi printer
This might be a dumb question.. I've upgraded my Ender 3 with a Duet 2 Wifi board and seeing how I'm going from Marlin to RepRap firmware, I was wondering if I need to tell my slicer, Simplify 3d in my case, that my printer is now using a different firmware..
Ideally, yes. You should set the gcode flavour to RepRapFirmware. This usually tells the slicer to use the gcode syntax particular to your firmware.
I don't use S3D, but maybe this will help.
https://forum.simplify3d.com/viewtopic.php?t=1944If you're using recent firmware for the Duet, it will accept the common Marlin gcodes as well as the RepRap versions.
