    Idex printer compatible stepper drivers
    483
    • Damir
      Damir last edited by
      I am building idex printer. I need additional stepper driver for x axis. What stepper driver board you recommending me to connect on expansion board for aditional X axes.
      • dragonn
        dragonn last edited by
        Duex2 or Duex5 will be the best solution
          dc42 administrators @dragonn last edited by
          @dragonn said in Idex printer compatible stepper drivers:
          Assuming of course that your main electronics is Duet WiFi or Duet Ethernet. Or you could use Duet Maestro electronics with the additional 2-stepper driver daughter board, which will be in our shop very soon.
          • Damir
            Is it possible to use this:
            https://duet3d.com/Expansion_Breakout
            On this connect additional step drivers compatible to TMC2660. I cant find board with TMC2660
            • T3P3Tony
              T3P3Tony administrators @Damir last edited by T3P3Tony
              @damir This is the expansion board with the built in TMC2660s.
              https://www.duet3d.com/Duex5
              www.duet3d.com
                dc42 administrators @T3P3Tony last edited by
                @t3p3tony said in Idex printer compatible stepper drivers:
                Meaning that DueX2 and DueX5 are the expansion boards with TMC2660 drivers.
                • Damir
                  I don't want to use duex board. I was talking about expansion board.
                  • T3P3Tony
                    @damir that board is for conencting external driver modules/boards that take a differential signal. for example:
                    https://www.omc-stepperonline.com/digital-stepper-drive-24-72a-20-80vdc-for-nema-34-stepper-motor-cnc-kit-dm860i.html
                    If you don't want to use a Duex then I am unaware of another option that uses TMC2660s
                    www.duet3d.com
                    • Damir
                      I look little more on DUET wifi wiring diagram. I can connect TMC2208 Stepper Motor Driver module/board directly on DUET 2 expansion connector. For example on pins 4,5,6,7 (E2-stop, E2-step,E2-dir and E2-en).
                      Is this correct?
                      • bricor
                        bricor last edited by
                        I was in the same situarion and weighed out the pros and cons. I understand there is a cost to cosider but it doesn’t make sense to take the risk of destroying the Duet main board. Call it insurance if you must.
                        There is a lot of value (forget cost) in these products that a lot of people don’t recognize. Also, add up the time and materials, the cost difference isn’t that much if you use quality parts. To use knockoff parts is just silly.
                        One more thing to consider is serting up firmware, why recreate the wheel? There is a lot of support when using the Duet with the Duex especially for IDEX.
                        I cant tell you how easy it is setting up the printer using the Duet/Duex pair and the supplied docs and files.
                        Damir 1 Reply Last reply Reply Quote 0
                        • Damir
                          Damir @bricor last edited by
                          @bricor I considering deux board only for further development of some other functionality. On idex printer to use duex board for only one step driver there is no sens. One of reason for this is that DUET is very well documented. There is no reason to destroy a board.
                          https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
                          Here are and the commands for setting firmware.
