Duet Wifi Repair Service
Hello All,
I have two duet wifi boards and a panel due that need repair. Can anyone suggest where I can send them.
Best,
Paul
I'm sure it'll help if you provide a rough idea of where the boards are, and what kind of problems there are.
If you know whats wrong, a descent phone repair shop should be able to replace parts, if you need troubleshooting thats a different ball game etc.
Thank you @bearer I am in Buffalo, NY.
Neither of the boards have any physical damage as far as I can tell.
Board 1: I moved my printer to a more stable table and I believe the panel due connection was loose when I reconnected it and then the board got really hot not even plugged in to power ( I read this means I have a problem with my processor?)
My panel due is also damaged, it lights up a black screen but does not show anything.
Board 2: Due to loose wires connectivity to the firmware became flakey and the fan and Z probe stopped working
Best,
Paul
Try sending a PM to forum user W3DRK.
@pauljsr have you.managed to get anywhere with diagnosing why your setup is damaging the Duets?
Thank you @dc42
@T3P3Tony yes thankfully I have my machine up and running. It is a Tronxy X5ST 500x500x600mm with a titan aero, bl touch and of course a duet wifi. Lot of hours being that I am new to this but happy with the result.
