    duet2 ethernet expansion board heater 6
    653
    • JVundefined
      JV
      Hello Guys i have a problem that i can't solve
      I'm trying to drive a relay with an io pins.
      In my expansion board i have the heater number 6 and i disable it with M307 H6 A-1 C-1 D-1 in config.g
      But when i trying to used with M42 P6 S1, an error came out telling me
      M42 P6 S1
      Error: M42: Logical pin 6 is not available for writing
      I try it to do this with the fan1 output and the solid state relay works when i have to put it on.
      But when i put it off, the relay light turn off but the contact in the relay stay close, any body can tell me why this happens?
      Thank you so much
      • CHANGE3D GmbHundefined
        CHANGE3D GmbH
        Hi JV
        Did you check if your disabled heater gets overwriten in the config-override.g file?
        Best,
        Markus
        www.change3d.ch
        info@change3d.ch
        JVundefined 1 Reply Last reply Reply Quote 1
        • JVundefined
          JV @CHANGE3D GmbH
          @change3d-gmbh
          Thanks for your reply, i found this in the config-override.g file
          M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
          I cancel it from that file and now it work.
          But i still having the same issue than the fan output, i mean the led in the FOTEK solid state relay that i connected to this output, is turning on and off with the M42 P6 S1 and M42 P6 S0 commands, but the contact stayed closed when i turn it off.
          That's why i decide to use the heater 6 outputs thinking that the problems was the fan output
          Thanks
            CHANGE3D GmbH
            Is it possible that the trigger current at heater pin 6 is too small?
            http://www.fotek.com.hk/solid/SSR-1.htm
            Could you try switching the relay on and off with the heatbed output just to test if the relay works?
            www.change3d.ch
            info@change3d.ch
              dc42 administrators @JV
              @jv, what model of Fotek SSR is it?
              JVundefined 1 Reply Last reply Reply Quote 0
              • JVundefined
                JV @dc42
                Fotek SSR10DA-H
                  @jv said in duet2 ethernet expansion board heater 6:
                  Fotek SSR10DA-H
                  Should be OK if you don't run too much current through it, that's the model I use to run my 240V 350W bed heater. However, many Fotek SSRs are fakes, typically using a lower rated triac than they should. When SSRs fail, they tend to go short-circuit. If the LED on the SSR is off, the triac should be off too.
                  • JVundefined
                    JV @dc42
                    Thanks guys for your help, i did change it with an Elco relay and it still not working...
                    There is any diference between fan1 output and heater 6 output for this application?
                    Thanks
                    • JVundefined
                      JV
                      Hi Guys, i found the problem.
                      The Fotek SSR10DA-H relay works with a load in AC voltage and i was working with 24VDC voltage load and it doesn't has zero crossing.
                      I use the SSR88D-360 from ELCO company and it works very fine.
                      Completely solved.
                      Thank you so much
