    Firmware work with COREXYZ ?
    • piperswundefined
      pipersw
      I have seen this coreXYZ : Core-xyz first motion with modded Repetier firmware!
      The Duet firmware works with this topology ?
      • T3P3Tonyundefined
        T3P3Tony administrators @pipersw
        @pipersw It looks like M669 will need to be extended to allow for the matrix to work with COREXYZ
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M669_Set_kinematics_type_and_kinematics_parameters
        www.duet3d.com
          dc42 administrators @T3P3Tony
          @t3p3tony said in Firmware work with COREXYZ ?:
          No need to extend M669, you can already specify whatever matrix you like.
