Unable to connect to DuetWIFI
Hi, Its been about 6 months since I used my printer, and now im having issues trying to connect to it.
I can confirm that the board (Duet WIFI) is connected to my network because when I check on my duet Panel, I get the message "WIFI Module is connected to access point ...........10.1.1.184"
If I log into my router, and can also see the printer is connected to 10.1.1.184I have run through this https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
set up page again, but im still unable to connect.
I found that I am running version 2.02If I type "10.1.1.184" into my Chrome address bar, I constantly get the unable to connect message.
I think im having an issue with my laptop maybe, like im forgetting a setting.
Your help would be greatly appreciated.
I can confirm that I am able to connect by wifi to the printer from my phone, just not my laptop.
hmmmmm, i'm very confused, but im sure someone here has the solution
From your laptop, open up command prompt.
Type ping 10.1.1.184For my printer it is 192.168.0.8 and these are my results.
C:\Users\Paul>ping 192.168.0.8Pinging 192.168.0.8 with 32 bytes of data:
Reply from 192.168.0.8: bytes=32 time=11ms TTL=128
Reply from 192.168.0.8: bytes=32 time=7ms TTL=128
Reply from 192.168.0.8: bytes=32 time=8ms TTL=128
Reply from 192.168.0.8: bytes=32 time=13ms TTL=128Ping statistics for 192.168.0.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 7ms, Maximum = 13ms, Average = 9msif you get similar results obviously with your printers ip, it is more than likely chrome.
Try a different browser like firefox or Internet Explorer/Edge.If that works you might have to add an 'exclusion' to Chrome to allow it to connect, basically the DWC is not secure so Chrome could be protecting you.
I know Chrome went through some big changes protecting the user.
Thanks for the reply.
I did the ping and got the similar results.
I tried to use edge, but got the same can not connect error.
It must be a windows firewall problem?
It is not the firewall, as the ping command goes throught the firewall too.
Please open command again and type ipconfig/all and post the results.
Also please post this section from you config.g
This is mine
M550 P"Cartesian" ; Set machine name
M552 P192.168.0.8 S1 ; Enable network and set IP address
M553 P255.255.255.0 ; Set netmask
M554 P192.168.0.1 ; Set gateway
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S1 ; Disable Telnet
C:\Users\nwith>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : LAPTOP-JOFNRE8S
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lanEthernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : B0-6E-BF-AC-76-6D
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : YesWireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : D6-25-8B-38-BD-E6
Autoconfiguration Enabled . . . . : YesWireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : D4-25-8B-38-BD-E7
Autoconfiguration Enabled . . . . : YesWireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 8265
Physical Address. . . . . . . . . : D4-25-8B-38-BD-E6
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:44b8:6130:fc00:79c8:c35b:e541:91e4(Preferred)
IPv6 Address. . . . . . . . . . . : fdbf:aa99:f3e5:0:79c8:c35b:e541:91e4(Preferred)
Temporary IPv6 Address. . . . . . : 2001:44b8:6130:fc00:10e9:ec1c:73ae:f8a5(Preferred)
Temporary IPv6 Address. . . . . . : fdbf:aa99:f3e5:0:919d:e27c:ad35:22fd(Preferred)
Temporary IPv6 Address. . . . . . : fdbf:aa99:f3e5:0:9435:ff6a:8ad9:9b76(Deprecated)
Link-local IPv6 Address . . . . . : fe80::79c8:c35b:e541:91e4%8(Preferred)
IPv4 Address. . . . . . . . . . . : 10.1.1.44(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : fe80::a691:b1ff:fe2c:a690%8
10.1.1.1
DHCPv6 IAID . . . . . . . . . . . : 81012107
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-D7-0D-B1-B0-6E-BF-AC-76-6D
DNS Servers . . . . . . . . . . . : fe80::a691:b1ff:fe2c:a690%8
192.231.203.132
192.231.203.3
NetBIOS over Tcpip. . . . . . . . : Enabled
Connection-specific DNS Suffix Search List :
lanEthernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : D4-25-8B-38-BD-EA
M550 P"RigidBot" ; Set machine name
M552 S1 ; Enable network
M587 S"WIFI Disconnected" P"***" I10.1.1.182 J10.1.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
M586 P2 S0 ; Disable Telnet
I think I see a problem.
The ip is set to 10.1.1.182, but my router is assigning 10.1.1.184.If this is a problem, how does my phone connect?
Your laptop is running not running DHCP and your subnet mask is wrong
Subnet Mask . . . . . . . . . . . : 255.255.255.255 Should be 255.255.255.0 which could cause an issue.Try setting your wireless lan to DHCP and try and connect to the printer again.
@geekness said in Unable to connect to DuetWIFI:
Because it is running DHCP, possibly
@PaulHew thanks heaps. Setting the laptop to enable DHCP has fixed the problem, although i'll need to look into being able to set my laptop ip as static to suit some other applications
Glad its fixed! Networks I know, 3d printing not much!
If I can help, please drop me a PM.Or post the ipconfig/all again and I will guide you through what to put where.
P.
