    Can not get past 183 deg on hot end
    • Dumbo
      Dumbo last edited by
      I have a E3D 24 v heater cartridge and can not get past 183 deg,s. I am stumped. here is my config.
      ; generated by RepRapFirmware Configuration Tool v2 on Sat Jun 08 2019 16:16:50 GMT+0100 (British Summer Time)
      M550 P"DAVES ENDER3" ; Set machine name
      M552 S1 ; Enable network
      M587 S"192.168.1.59" P"" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 ; Enable FTP
      M586 P2 S1 ; Enable Telnet
      M569 P0 S0 ; Physical drive 0 goes backwards
      M569 P1 S0 ; Physical drive 1 goes backwards
      M569 P2 S1 ; Physical drive 2 goes forwards
      M569 P3 S1 ; Physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z400.00 E93.00 ; Set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; Set accelerations (mm/s^2)
      M906 X400.00 Y400.00 Z400.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
      M208 X258.5 Y246 Z260 S0 ; Set axis maxima
      M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
      M558 P5 R0.4 H2.5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
      G31 P25 X-31 Y0 Z0.6 ; Set Z probe trigger value, offset and trigger height
      M557 X20:215 Y20:215 S20 ; Define mesh grid
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S320 ; Set temperature limit for heater 1 to 320C
      M106 P1 S1 I0 F500 H0 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H0:1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      it errors out with a took to long to get to temp after it hit 183. I asked it to go to 200. Any help please.
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @Dumbo last edited by
        @dumbo Looks like you haven't done a PID tune.
        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        • Dumbo
          tried that and it errors out at same point
          • PaulHew
            PaulHew last edited by
            Are you sure you have the correct paramters for your hotend?
            This is my config for E3D V6 on my Maestro
            M305 P0 T98801 B4185 R2200 ; Set thermistor + ADC parameters for heater 0
            M307 H0 A205.5 C822.3 D1.2 V24.1 B0 ; Bed PID
            M143 H0 S100 ; Set temperature limit for heater 0 to 100C
            M305 P1 T100000 B4725 C7.060000e-8 R2200 ; E3D - Set thermistor + ADC parameters for heater 1
            M307 H1 A551.6 C246.4 D3.5 V24.2 B0 ; PID Autotune
            M143 H1 S285 ; Set temperature limit for heater 1 to 280C
            HTH. Paul
            RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
            Voron 2.4 disassembled..... Waiting for the RailCore Mini....
            • Dumbo
              @paulhew said in Can not get past 183 deg on hot end:
              thanks I will have a look
                If it's an E3Dv6 hot end, check that you have assembled it correctly. There should be a gap of about 2mm between the top of the hearer block and the bottom fin of the heatsink.
