How to reduce ABS curling?
@antlestxp Sorry, I was going to include them but forgot. My extruder is 280C, bed is 110C, and chamber is 70C.
I know those sound way off, but see the previous posts. I've also experimented with the fan speeds above. Thanks for your help though!
Unless I'm reading it wrong, in the FFF settings, extruder tab it says you're trying to print 0.3mm wide lines with a 0.4 mm nozzle, and if that weren't bad enough, also using a 0.93 extrusion multiplier. That's not going to work.
If you try to print a too narrow line, it will tend to blob irregularly, and it will wander back and forth under the nozzle. The next layer will do the same and it will turn into a mess, and will make for a very weak print.
I'd never try to print a line width less than the nozzle diameter. In the bad old days, I let slic3r pick the line widths and it did that sort of thing. Once I figured out what was happening, I never let slic3r pick lines widths again. I don't know if they've fixed that or not in more recent releases.
@mrehorstdmd Thanks for your input!
I tried a 0.5 millimeter extrusion width but that didn't seem to cause any increase in quality. All it did was meet the part look coarser because the extrusions were wider.
My flashforge Creator pro has a 0.4 mm nozzle and I've noticed no adverse effects with a 0.3 millimeter extrusion width. Why is that?
Thanks for your help!
@jadonm I don't know why your other printer would work with those settings. It really shouldn't. Is it actually giving you 0.3mm wide lines? Picture the nozzle and the line of plastic it's laying down. How can a 0.4 mm diameter nozzle put down a 0.3 mm wide line with any precision? Is it going to lay down the line at the center of the nozzle- what would make it do that? Or off to one side or the other?
The print looks overextruded, yet it should be grossly underextruded based on your slicer settings. I think you need to run some basic extruder calibration. I'd set the line width to match the nozzle diameter for starters- minimize potential sources of error until it's working right.
Thanks all for your help! The wavy looking overhang happened to be the stl's problem. It was too low resolution, so the segments showed. The overhang seems to have exaggerated it.
Thanks again!
@jadonm I am also retrofitting a 3D systems machine, Mine is a CubePro single extruder. I also am a hardware guy, the Gcode thing is a little hard to get your head around. I did a lot of modifications to my machine. first was i changed it from a single Z motor, to 2 motors and screws, putting them right next to the Z linear bearings, I was having some issues with the platform binding, and the screws are finer pitch so should provide better z resolution. i also removed the ball bearings and put PBC linear, FMT12 frelon lined bushings in the bearing housings, they are a direct swap out. then i removed the 2 y axis motors, and put one larger dual shaft motor on the right side, with a driveshaft that goes to the left side, where the 2nd motor was, i made a bearing block that bolts up where the 2nd motor was. this way both belts are coupled together and no chance of skipped steps or getting the carriage out of square. i also changed to the FTM12 bushings in all the bearing blocks, also put larger and higher resolution (.9 deg )motors on the X and Y ( now 2 motors, not 3) the extruder carriage i started from scratch, Just got a new model Bondtech Dual BMG and 2 mosquito hot ends, machined new bearing slides, brackets, fans and bracket for the cable chain. this is what it looks like:
I also moved all the electronics from inside bottom to outside rear, put a carbon fiber panel where the clear rear panel was, and made a couple acrylic baffels and cooling fans on the back. and a lot of carbon fiber stiffening plates through out.
and last was the heated bed, i made new parts, 1000 watt silicone heater, garolite, and a aluminum heat plate with imbedded magnets.
