Solved Banging head against a brick wall Request Help!
Hello All,
I'm new to the forum and Duet 3d.
I recently purchased a duet wifi board for my Ender 5, and for the last 3 days I've been trying to get it working. It took me two days to get it to home correctly and now the current situation is that it homes, but when I start a print (using Cura 4.1) it heats up correctly it then lifts then lowers the bed slightly to purge head, it then starts to draw a line BUT it doesn't stop the X keeps going to the end of the frame and i have to hit the emergency stop!
I have been searching but can find very little on the Ender 5 with a Duet board. I have tried changing my start code in Cura and I have used a Ender 3 profile in case it was the Creawesome Ender 5 profile causing the issue, all do the same.
Here is my config:
; generated by RepRapFirmware Configuration Tool v2 on Sat Jun 29 2019 12:25:11 GMT+0100 (British Summer Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"Ender 5" ; Set machine name
M551 P"r35d" ; Set password
M552 S1 ; Enable network
M587 S"WiFi" P"Password" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Physical drive 0 goes forwards
M569 P1 S1 ; Physical drive 1 goes forwards
M569 P2 S0 ; Physical drive 2 goes backwards
M569 P3 S1 ; Physical drive 3 goes forwards
M92 X160.00 Y160.00 Z400.00 E450.00 ; Set steps per mm
M566 X600.00 Y600.00 Z60.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z600.00 E600.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z200.00 E4000.00 ; Set accelerations (mm/s^2)
M906 X850.00 Y800.00 Z700.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X220 Y220 Z300 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; Set active high endstops; Z-Probe
M558 P0 H5 F0 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
M557 X15:220 Y15:220 S40 ; Define mesh grid; Heaters
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S0.5 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
And here is my current start code:
(Ender 3 Profile)
G28 ;Home
G1 Z15.0 F6000 ;Move the platform down 15mm
;Prime the extruder
G92 E0
G1 F200 E3
G92 E0(Ender 5 Profile)
G28 ; home all axes
M117 Purge extruder
G92 E0; reset extruder G1 Z1.0 F3000 ; move z up little to prevent scratching of surface
G1 X0.1 Y20 Z0.3 F5000.0 ; move to start-line position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; draw 2nd line
G92 E0 ; reset extruder
M117 All systems go!Please help
Your X and Y steps/mm are both 160 which implies that you are using 0.9deg motors. Is that correct? Do the axes move by the correct amounts?
Thanks for the reply.
My motors are standard which I presume are 1.8. This is my first time getting in depth with G code. I should also note that the head is moving a lot slower than when it was running Marlin.
@oscar said in Banging head against a brick wall Request Help!:
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1these are incorrect for the ender 3 and 5.
see the ender 3 guide. (ender 5 is basically a more stable ender 3)
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
Thanks, I'll take a look
I followed the guide, thanks. However when I tried a test print, small overhang scale, it immediately started to print in the homing corner and didn't extrude anything. Am I right in thinking that this is possibly to do with the cura settings? As the machine now homes perfectly.
It's up to you whether to make X0 Y0 the centre of the bed (which is what I do) or to make it one corner of the bed. See https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin. You need to configure your slicer (Cura) accordingly. It sounds to me that you have configured X0 Y0 to be one corner of the bed but configured Cura to centre the print on X0 Y0.
You may want to go through the rest of that configuration and commissioning guide for the Ender 3. It also includes a profile for Cura for the Ender 3 which should have everything setup correctly for orientation. I think you might also have a motor direction or homing direction flipped. The guide would help you identify it.
@phaedrux thanks will do
This post is deleted! -
Can you post your full config?
@phaedrux Thanks for the swift reply phaedrux. I'm glad to say that the action of copying my heater config into chat made me realise the figures were wrong, so I popped into config and changed them. It appears to be working fine now, I'm just running a M307.
I am grateful for the help. It's good to know that there is a place for advice, I'm currently suffering from a psychological disorder that makes it hard for me to concentrate for large periods of time and also makes it difficult to problem solve.
So your help is appreciated.
Glad you got it figured out. There's always great support from many people here, so come on back whenever you get stuck.
