    notifications upon start/pause/finish of print
    Third-party software
    18
    65
    6.5k
    • Torinundefined
      Torin @chrishamm
      @chrishamm Many thanks for that, it definitely extends what I've seen.
      However I am missing a 'final status' if that makes sense e.g. there's the status for cancelling yet there's no cancelled status or processing and no processed which makes it hard to understand and put the proper function in place to determine final status without hammering the API and making a request every let say 100ms which could still lead to some false positives.
      stuartofmtundefined 1 Reply Last reply Reply Quote 0
      • stuartofmtundefined
        stuartofmt @Torin
        @torin
        This may help. Its some of the logic in DuetLapse3. It ends up being a bit convoluted .... and of course I have a bunch of defensive coding in here (for other reasons).
        The main logic starts at line 16.
        Any yes - it can do with a bit of tidying up 😞
        def captureLoop():  # Run as a thread
            global printState, duetStatus, captureLoopState
            if connectionState is False:
                return
            captureLoopState = 1
            printState = 'Not Capturing'
            lastDuetStatus = 'idle' # logical state on start of each thread instance
            logger.debug('Starting Capture Loop')
            while captureLoopState == 1:  # Set to 0 to stop. e.g  By http listener or SIGINT or CTL+C
                if duetStatus != lastDuetStatus:  # What to do next?
                    logger.info('****** Duet status changed to: ' + str(duetStatus) + ' *****')
                    # logical states for printer are printing, completed
                    if duetStatus == 'idle' and printState in ['Capturing', 'Busy'] and terminateState != 1:  # Capturing is finished without being commanded
                        printState = 'Completed'
                        logger.debug('****** Print State changed to ' + printState + ' *****')
                    elif duetStatus in ['processing', 'idle'] or (duetStatus == 'paused' and detect == 'pause'):
                        printState = 'Capturing'
                        logger.debug('****** Print State changed to: ' + printState + ' *****')
                    elif duetStatus == 'busy':
                        printState = 'Busy'
                    else:
                        printState = 'Waiting'
                    logger.info('****** Print State changed to: ' + printState + ' *****')
                if printState == 'Capturing':
                    oneInterval('Camera1', camera1, weburl1, camparam1)
                    if camera2 != '':
                        oneInterval('Camera2', camera2, weburl2, camparam2)
                    unPause()  # Nothing should be paused at this point
                elif printState == 'Completed':
                    logger.info('Print Job Completed')
                    # use a thread here as it will allow this thread to close.
                    startnextAction('completed')
                    break # Do not want to wait to end
                if captureLoopState == 1 and terminateState != 1 and connectionState:  # If still running then sleep
                    lastDuetStatus = duetStatus
                    time.sleep(poll)
            captureLoopState = -1
            return  # End of captureLoop
        Torinundefined 1 Reply Last reply Reply Quote 0
        • Torinundefined
          Torin @stuartofmt
          Hey folks,
          I want to share a download link with the version that should now work with v2 and v3 API.
          If you could test it and let me know if it's all good that we'd be great and I will release it officially.
          Only change you need to make is additional entry in your configuration file adding api_version in the connection section(v2 or v3) e.g.:
          connection:
            host: 192.168.0.11
            polling_time: 30
            error_count: 5
            api_version: v3
          Without further ado:
          https://1drv.ms/u/s!Aq3gq6mIQqpsisE-e3Adz3wsP6dAJw
          Link is going to expire in 2 weeks, after that I will just merge it 🙂
          stuartofmtundefined Nxt-1undefined 2 Replies Last reply Reply Quote 0
            stuartofmt @Torin
            @torin
            Don't know if this is interesting for you but may avoid having the user input the version /model info. Its Python, but the logic will be the same.
            def getDuetVersion(model):
                # Used to get the API and version information from Duet
                if model == '' or model == 'rr_model':
                        URL = ('http://' + duet + '/rr_model?key=boards')
                        r = urlCall(URL, 3, False)
                        if r.ok:   #The API type is rr_model
                            try:
                                j = json.loads(r.text)
                                version = j['result'][0]['firmwareVersion']
                                return 'rr_model', version
                            except:
                                pass
                if model == '' or model == 'SBC':
                        #  model = '/machine/status'
                        URL = ('http://' + duet + '/machine/status')
                        if r.ok:
                            try:
                                version = j['boards'][0]['firmwareVersion']
                                return 'SBC', version
                            except:
                                pass
            • Torinundefined
              Torin @stuartofmt
              @stuartofmt Cool. I'll have a look tomorrow (that is if I will survive tomorrow heatwave...). Cheers buddy.
                stuartofmt @Torin
                @torin
                Ha! - good day to be indoors and futzing with play code 🙂
                Good Luck. BTW what programming language are you using?
                Part of the reason I ask is that I also have some code for using gmail.
                I don't actually use your program as I use DuetMonitor (which only supports gmail) - but it you wanted to extend your connection capabilities - I can sling it in your direction.
                I
                • Torinundefined
                  Torin @stuartofmt
                  @stuartofmt Ah that's quite cool. I've already put that in, however I stripped in my case and just checked for the appropriate content-type header on each URL, in both cases it should be app/json, otherwise it's just wrong.
                  I'm doing it all in golang, since it's quite nice for such nice things and portability and lack of dependencies.
                  I have notifications for any email service assuming it can do smtp so should in theory work everywhere. Can you point me to this duetmonitor? First time I'm hearing about this and haven't seen it.
                  If you want to poke around code and see what's there, that's the current that will go to master soon.
                  https://gitlab.com/Toriniasty/reprap_notify/-/tree/feature/apiV3/
                  • Nxt-1undefined
                    Nxt-1 @Torin
                    @torin I tried the new version but could not get past identifying v2 of v3 firmware.
                    Printer is a Duet3 6HC in SBC mode, attached to a Jetson Nano (arm64). That name Nano also runs your project.
                    Top of rrnotity.yaml looks like this (dwc is running on port 8080)
                    connection:
                      host: localhost:8080
                      polling_time: 5
                      error_count: 50
                      api_version: v3
                    Running the rr_notify results is this output:
                    2022/07/19 00:40:18 Detecting API version...
                    2022/07/19 00:40:18 Couldn't identify v2 or v3 firmware
                    panic: Couldn't identify v2 or v3 firmware
                    goroutine 1 [running]:
                    log.Panicf({0x463b71?, 0x454fd0?}, {0x0?, 0x1?, 0x400022a030?})
                    	/usr/local/go/src/log/log.go:392 +0x6c
                    main.main()
                    	/builds/Toriniasty/reprap_notify/cmd/rr_notify/main.go:71 +0x46c
                    I am not sure how to proceed from here or how to debug. ¯_(ツ)_/¯
                    Duet3D and delta printer enthousiast. Buildlog
                    Looking for Duet3D configuration support, check out Nxt-3D
                      stuartofmt @Torin
                      @torin said in notifications upon start/pause/finish of print:
                      Here is DuetMonitor
                      https://forum.duet3d.com/topic/23282/duetmonitor
                      • Torinundefined
                        Torin @Nxt-1
                        @nxt-1 hiya, would you be able to provide me output from these two commands(run from the nano itself):
                        curl -v http://localhost:8080/machine/system
                        curl -v http://localhost:8080/rr_model?key=boards
                        Nxt-1undefined 1 Reply Last reply Reply Quote 0
                        • Nxt-1undefined
                          Nxt-1 @Torin
                          @torin They result in a 404 for both, though I would not be able to guess why since the base address does seem to be reachable, though understandably complaining about the lack of JS.
                          *   Trying 127.0.0.1...
                          * TCP_NODELAY set
                          * Connected to localhost (127.0.0.1) port 8080 (#0)
                          > GET /rr_model?key=boards HTTP/1.1
                          > Host: localhost:8080
                          > User-Agent: curl/7.58.0
                          > Accept: */*
                          < HTTP/1.1 404 Not Found
                          < Content-Length: 0
                          < Date: Tue, 19 Jul 2022 14:44:56 GMT
                          < Server: Kestrel
                          * Connection #0 to host localhost left intact
                          * Rebuilt URL to: http://localhost:8080/
                          * TCP_NODELAY set
                          > GET / HTTP/1.1
                          > Accept: */*
                          < HTTP/1.1 200 OK
                          < Content-Length: 1441
                          < Content-Type: text/html
                          < Date: Tue, 19 Jul 2022 14:47:27 GMT
                          < Server: Kestrel
                          < Accept-Ranges: bytes
                          < ETag: "1d8772d0a7368a1"
                          < Last-Modified: Fri, 03 Jun 2022 09:33:54 GMT
                          <!DOCTYPE html><html lang="en"><head><meta charset="utf-8"><meta http-equiv="X-UA-Compatible" content="IE=edge"><meta name="viewport" content="width=device-width,initial-scale=1,user-scalable=0"><!--[if IE]><link rel="icon" href="/favicon.ico"><![endif]--><title>Duet Web Control</title><link href="/css/app.62f87138.css" rel="preload" as="style"><link href="/js/app.d9dc885b.js" rel="preload" as="script"><link href="/css/app.62f87138.css" rel="stylesheet"><link rel="icon" type="image/png" sizes="32x32" href="/img/icons/favicon-32x32.png"><link rel="icon" type="image/png" sizes="16x16" href="/img/icons/favicon-16x16.png"><link rel="manifest" href="/manifest.json"><meta name="theme-color" content="#2196f3"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-status-bar-style" content="black"><meta name="apple-mobile-web-app-title" content="Duet Web Control"><link rel="apple-touch-icon" href="/img/icons/apple-touch-icon-152x152.png"><link rel="mask-icon" href="/img/icons/safari-* Connection #0 to host localhost left intact
                          pinned-tab.svg" color="#2196f3"><meta name="msapplication-TileImage" content="/img/icons/msapplication-icon-144x144.png"><meta name="msapplication-TileColor" content="#000000"></head><body><noscript><strong>We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id="app"></div><script src="/js/app.d9dc885b.js"></script```
                          • Torinundefined
                            Torin @Nxt-1
                            @nxt-1 Right, so the second paste is wrong and missing URI 🙂 and I had a thought as well, since there's '?' in URI bash might be screwing around with it try again with:
                            curl -v "http://localhost:8080/rr_model?key=boards"
                            • Nxt-1undefined
                              Nxt-1 @Torin
                              I did in fact ment to post it without URI, just to show that can I fact make a connection.
                              Here's the two requests, as requested 🙂
                              * TCP_NODELAY set
                              > GET /machine/system HTTP/1.1
                              > Accept: */*
                              < Content-Length: 0
                              < Date: Tue, 19 Jul 2022 15:39:09 GMT
                              < Server: Kestrel
                              * TCP_NODELAY set
                              > Accept: */*
                              < Content-Length: 0
                              < Date: Tue, 19 Jul 2022 15:39:18 GMT
                              < Server: Kestrel
                              • Torinundefined
                                Torin @Nxt-1
                                @nxt-1 That's bit odd according to the previous post it should be either one of those two URLs.
                                @stuartofmt / @chrishamm any idea why either doesn't work?
                                • chrishammundefined
                                  chrishamm administrators @Torin
                                  @torin It's /machine/status, not /machine/system. Support for rr_ requests will come in v3.5.
                                  Duet software engineer
                                  • Torinundefined
                                    Torin @chrishamm
                                    @chrishamm Awesome, thanks for the great spot, not sure how I missed it.
                                    @Nxt-1 would you mind giving it another go please? also api_version not needed anymore, software will try to detect it automatically.
                                    • Nxt-1undefined
                                      Nxt-1 @Torin
                                      @torin /machine/status does give me a wall of json output 🙂 .
                                      curl -v http://localhost:8080/machine/status
                                      * TCP_NODELAY set
                                      > GET /machine/status HTTP/1.1
                                      > Accept: */*
                                      < HTTP/1.1 200 OK
                                      < Content-Length: 14094
                                      < Content-Type: application/json
                                      < Date: Wed, 20 Jul 2022 13:45:18 GMT
                                      < Server: Kestrel
                                      {"boards":[{"accelerometer":null,"bootloaderFileName":null,"canAddress":0,"closedLoop":null,"directDisplay":null,"firmwareDate":"2022-06-01","firmwareFileName":"Duet3Firmware_MB6HC.bin","firmwareName":"RepRapFirmware for Duet 3 MB6HC","firmwareVersion":"3.4.1","iapFileNameSBC":"Duet3_SBCiap32_MB6HC.bin","iapFileNameSD":"Duet3_SDiap32_MB6HC.bin","maxHeaters":32,"maxMotors":6,"mcuTemp":{"current":44,"min":39.8,"max":50.4},"name":"Duet 3 MB6HC","shortName":"MB6HC","state":"unknown","supports12864":false,"supportsDirectDisplay":false,"uniqueId":"08DJM-9P63L-DJMSS-6JKD0-3S06T-9AF79","v12":{"current":12.3,"min":12.2,"max":12.4},"vIn":{"current":32.1,"min":31.9,"max":32.3}}],"directories":{"filaments":"0:/filaments/","firmware":"0:/firmware/","gCodes":"0:/gcodes/","macros":"0:/macros/","menu":"0:/menu/","scans":"0:/scans/","system":"0:/sys","web":"0:/www/"},"fans":[{"actualValue":0,"blip":0.1,"frequency":2000,"max":0.7,"min":0,"name":"Compressor","requestedValue":0,"rpm":-1,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":1,"blip":0.1,"frequency":25000,"max":1,"min":0,"name":"Duet","requestedValue":1,"rpm":2039,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":1,"blip":0.1,"frequency":25000,"max":1,"min":0,"name":"Pump","requestedValue":1,"rpm":4539,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}}],"global":{},"heat":{"bedHeaters":[0,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1],"chamberHeaters":[-1,-1,-1,-1],"coldExtrudeTemperature":160,"coldRetractTemperature":90,"heaters":[{"active":0,"avgPwm":0,"current":33.6,"max":150,"min":-273.1,"model":{"coolingExp":1.4,"coolingRate":0.138,"deadTime":19.5,"enabled":true,"fanCoolingRate":0,"heatingRate":0.577,"inverted":false,"maxPwm":1,"pid":{"d":0.849,"i":0.0008,"overridden":false,"p":0.06221,"used":true},"standardVoltage":0},"monitors":[{"action":1,"condition":"tooHigh","limit":150},{"action":0,"condition":"disabled","limit":0},{"action":0,"condition":"disabled","limit":0}],"sensor":0,"standby":0,"state":"off"},{"active":0,"avgPwm":0,"current":29.2,"max":285,"min":-273.1,"model":{"coolingExp":1.4,"coolingRate":0.319,"deadTime":5.4,"enabled":true,"fanCoolingRate":0.038,"heatingRate":1.825,"inverted":false,"maxPwm":1,"pid":{"d":0.268,"i":0.0029,"overridden":false,"p":0.07116,"used":true},"standardVoltage":32.1},"monitors":[{"action":0,"condition":"tooHigh","limit":285},{"action":0,"condition":"disabled","limit":0},{"action":0,"condition":"disabled","limit":0}],"sensor":1,"standby":0,"state":"off"}]},"httpEndpoints":[],"inputs":[{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"HTTP","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Telnet","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":10.5,"inMacro":false,"macroRestartable":false,"name":"File","stackDepth":0,"state":"idle","lineNumber":270768,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"USB","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Aux","stackDepth":0,"state":"reading","lineNumber":7,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Trigger","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Queue","stackDepth":0,"state":"idle","lineNumber":270768,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"LCD","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"SBC","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Daemon","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Aux2","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Autopause","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false}],"job":{"build":null,"duration":null,"file":{"filament":[7056],"fileName":null,"generatedBy":"Simplify3D(R) Version 4.1.2","height":33.1,"lastModified":"2022-07-17T15:13:52","layerHeight":0.2,"numLayers":165,"printTime":7380,"simulatedTime":4309,"size":7460736,"thumbnails":[]},"filePosition":7460476,"lastDuration":4298,"lastFileName":"0:/gcodes/LampAdapter.gcode","lastFileAborted":false,"lastFileCancelled":false,"lastFileSimulated":false,"layer":null,"layers":[],"layerTime":null,"pauseDuration":null,"rawExtrusion":null,"timesLeft":{"filament":null,"file":null,"slicer":null},"warmUpDuration":null},"limits":{"axes":15,"axesPlusExtruders":25,"bedHeaters":12,"boards":21,"chamberHeaters":4,"drivers":26,"driversPerAxis":8,"extruders":16,"extrudersPerTool":10,"fans":20,"gpInPorts":32,"gpOutPorts":32,"heaters":32,"heatersPerTool":20,"monitorsPerHeater":3,"restorePoints":6,"sensors":56,"spindles":4,"tools":50,"trackedObjects":40,"triggers":32,"volumes":1,"workplaces":9,"zProbeProgramBytes":8,"zProbes":4},"messages":[],"move":{"axes":[{"acceleration":1000,"babystep":0,"current":2400,"drivers":["0.2"],"homed":false,"jerk":400,"letter":"X","machinePosition":-5.392,"max":200,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":-200,"minProbed":false,"percentCurrent":100,"percentStstCurrent":71,"speed":10000,"stepsPerMm":160,"userPosition":-5.365,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":2400,"drivers":["0.1"],"homed":false,"jerk":400,"letter":"Y","machinePosition":-24.104,"max":200,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":-200,"minProbed":false,"percentCurrent":100,"percentStstCurrent":71,"speed":10000,"stepsPerMm":160,"userPosition":-23.984,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":2400,"drivers":["0.0"],"homed":false,"jerk":400,"letter":"Z","machinePosition":133.866,"max":770.05,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"percentCurrent":100,"percentStstCurrent":71,"speed":10000,"stepsPerMm":160,"userPosition":133.2,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}],"calibration":{"final":{"deviation":0.037,"mean":0},"initial":{"deviation":0.038,"mean":-0.033},"numFactors":8},"compensation":{"fadeHeight":null,"file":null,"liveGrid":null,"meshDeviation":null,"probeGrid":{"axes":["X","Y"],"maxs":[188.8,188.8],"mins":[-188.7,-188.7],"radius":190,"spacings":[41.9,41.9]},"skew":{"compensateXY":true,"tanXY":0,"tanXZ":0,"tanYZ":0},"type":"none"},"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"extruders":[{"acceleration":3000,"current":750,"driver":"0.3","filament":"","factor":1,"jerk":2000,"microstepping":{"interpolated":true,"value":16},"nonlinear":{"a":0,"b":0,"upperLimit":0.2},"percentCurrent":100,"percentStstCurrent":71,"position":7053.9,"pressureAdvance":0.14,"rawPosition":7054.8,"speed":10000,"stepsPerMm":414}],"idle":{"factor":0.6,"timeout":30},"kinematics":{"deltaRadius":231.522,"homedHeight":770.057,"printRadius":200,"towers":[{"angleCorrection":-0.02,"diagonal":501.3,"endstopAdjustment":0.413,"xPos":-200.544,"yPos":-115.692},{"angleCorrection":-0.091,"diagonal":501.3,"endstopAdjustment":-0.814,"xPos":200.319,"yPos":-116.08},{"angleCorrection":0,"diagonal":501.3,"endstopAdjustment":0.402,"xPos":0,"yPos":231.522}],"xTilt":-0.009,"yTilt":0.003,"name":"delta","segmentation":null},"limitAxes":true,"noMovesBeforeHoming":true,"printingAcceleration":20000,"queue":[{"gracePeriod":0.01,"length":60},{"gracePeriod":0.01,"length":5}],"rotation":{"angle":0,"centre":[0,0]},"shaping":{"amplitudes":[],"damping":0.1,"durations":[],"frequency":40,"minAcceleration":0,"type":"none"},"speedFactor":1,"travelAcceleration":20000,"virtualEPos":0,"workplaceNumber":0},"network":{"corsSite":null,"hostname":"server","interfaces":[{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"AE:A2:57:DA:70:FA","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"48:B0:2D:3D:3E:E4","numReconnects":null,"signal":null,"speed":10,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"A6:73:89:4F:B4:35","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"A6:73:89:4F:B4:35","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"A6:73:89:4F:B4:37","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":"172.17.0.1","configuredIP":"172.17.0.1","dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"02:42:A8:9B:B4:7D","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":"255.255.0.0","type":"lan"},{"activeProtocols":[],"actualIP":"192.168.178.22","configuredIP":"192.168.178.22","dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":"192.168.178.1","mac":"58:96:1D:13:6F:0A","numReconnects":null,"signal":-71,"speed":0,"state":"active","subnet":"255.255.255.0","type":"wifi"}],"name":"server"},"plugins":{},"scanner":{"progress":0,"status":"D"},"sensors":{"analog":[{"lastReading":33.6,"name":"Bed","type":"thermistor"},{"lastReading":29.2,"name":"Hotend","type":"thermistor"}],"endstops":[{"highEnd":true,"triggered":false,"type":"inputPin"},{"highEnd":true,"triggered":false,"type":"inputPin"},{"highEnd":true,"triggered":false,"type":"inputPin"}],"filamentMonitors":[],"gpIn":[],"probes":[{"calibrationTemperature":25,"deployedByUser":false,"disablesHeaters":false,"diveHeight":5,"lastStopHeight":-0.116,"maxProbeCount":10,"offsets":[0,0,0.1],"recoveryTime":0.5,"speeds":[1000,1000],"temperatureCoefficients":[0,0],"threshold":100,"tolerance":0.03,"travelSpeed":10000,"triggerHeight":-0.1,"type":8,"value":[0]}]},"spindles":[{"active":0,"canReverse":false,"current":0,"frequency":0,"min":60,"max":10000,"state":"unconfigured"},{"active":0,"canReverse":false,"current":0,"frequency":0,"min":60,"max":10000,"state":"unconfigured"},{"active":0,"canReverse":false,"current":0,"frequency":0,"min":60,"max":10000,"state":"unconfigured"},{"active":0,"canReverse":false,"current":0,"frequency":0,"min":60,"max":10000,"state":"unconfigured"}],"state":{"atxPower":null,"atxPowerPort":null,"beep":null,"currentTool":0,"deferredPowerDown":null,"displayMessage":"","dsfVersion":"3.4.1","dsfPluginSupport":true,"dsfRootPluginSupport":false,"gpOut":[],"laserPwm":null,"logFile":null,"logLevel":"off","messageBox":null,"machineMode":"FFF","macroRestarted":false,"msUpTime":230,"nextTool":0,"pluginsStarted":false,"powerFailScript":"","previousTool":-1,"restorePoints":[{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,238.806],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":* Connection #0 to host localhost left intact
                                      50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1}],"status":"idle","thisInput":null,"time":"2022-07-20T15:44:46","upTime":4052689},"tools":[{"active":[0],"axes":[[0],[1]],"extruders":[0],"fans":[0],"feedForward":[0],"filamentExtruder":0,"heaters":[1],"isRetracted":false,"mix":[1],"name":"Hotend","number":0,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":0.9,"speed":45,"unretractSpeed":45,"zHop":0.1},"spindle":-1,"spindleRpm":0,"standby":[0],"state":"active"}],"userSessions":[{"accessLevel":"readWrite","id":33,"origin":"94.105.126.101","originId":-1,"sessionType":"http"}],"volumes":[{"capacity":236242378752,"freeSpace":220662013952,"mounted":true,"name":null,"openFiles":null,"partitionSize":236242378752,"path":"/","speed":null}]}
                                      However launching the updated executable I get continous json errors:
                                      (I am running rrf 3.4.1 fyi)
                                      ./reprap_notify_linux_arm64
                                      2022/07/20 15:48:57 Detecting API version...
                                      2022/07/20 15:48:57 Detected firmware revision 2
                                      2022/07/20 15:48:57 Error parsing JSON: unexpected end of JSON input
                                      • Torinundefined
                                        Torin @Nxt-1
                                        @nxt-1 Interesting, can you provide me full curl of:
                                        curl -v 'http://localhost:8080/rr_status?type=3'
                                        curl -v http://localhost:8080/rr_fileinfo
                                        (those two below probably will not work)
                                        curl -v 'http://localhost:8080/rr_model?key=job'
                                        curl -v 'http://localhost:8080/rr_model?key=state'
                                        • Nxt-1undefined
                                          Nxt-1 @Torin
                                          curl -v 'http://localhost:8080/rr_status?type=3' -> 404
                                          curl -v http://localhost:8080/rr_fileinfo -> 404
                                          curl -v 'http://localhost:8080/rr_model?key=job' -> 404
                                          curl -v 'http://localhost:8080/rr_model?key=state' -> 404
                                          Which makes sense, since Chrishamm mentioned the rr_ system wil be introduced in v3.5
                                          • Nxt-1undefined
                                            Nxt-1 @Nxt-1
                                            @Torin So, it's been a while. I finaly broke down and installed a Go environment so I can play around with your project.
                                            What I belive is going on is that there is rrf3 and 2, which your latested beta does differentiate between, though not entirely correct. Within rrf3 a subdivision must be made between the SBC version and the standalone version. The standalone version (rrf3) will get detected as is and work as intended (I assume I cannot test this). Rrf2 will also work I believe (again, I cannot test this). However, SBC mode (rrf3) will not work since it uses the /machine/status syntax which will lead it down the rrf2 branch of your code. That wont work as rr_status is deprecated and returns resulting in a empty response. Which is obviously not json parsable, hence the continuous json errors I reported earlier. @chrishamm please correct me if I am wrong at any point here.
                                            What I belive needs to change to make all of this work:
                                            • Expand the api version check in main to handle rrf3 sbc as a separate case (or pass the version/type as a config parameter again)
                                            • Make a 3rd handler for rrf3 sbc that uses /machine/status to get the full object model and takes the data it needs from it
                                              -> I've changed the v2handler to package for now as an example on how this could work, check the files attached below
                                            Some other changes I think would be useful if added:
                                            • Make the connection protocol part of the host parameter. I.e. add the http part in there as well. For example my machine normally does not listen to http requests so making this user changeable would save some hassle on my side 😇
                                            • Add the same delay to the loop in case of errors, so the loop does not run at mach3 🙂
                                            Example implementation for rrf3 sbc handler (currently sits in place of the v2 handler)
                                            v2_handler.gcode
                                            types.gcode
                                            chrishammundefined 1 Reply Last reply Reply Quote 1
