Source for Duex V0.9
  • I recently purchased a Duex2 and the PCB says it is V0.9. I can only find the source for V0.8 here https://github.com/T3P3/Duet/tree/master/Duet_Expansion. Am I looking in the wrong place or is it not released yet?
    @nophead thanks for the reminder - will upload it now
  • Thanks. I am making an OpenSCAD model, which is why I wanted an up to date PCB layout.
    @nophead ahh. Its a pity this Duex 5 is done in an old version of KiCAD and the 3d models for the components are not populated:
    Exporting a Step file from KiCAD works OK but first all the components need to be setup which takes rather a long time.
  • Yes but OpenSCAD doesn't read STEP files, so I model everything from scratch. I only do a rough mock up.
  • @nophead you can easily convert STEP to STL, they are many ways do do it
  • Yes but STL is all one colour and I can't get information from it, like screw hole positions. With my own models I can also make holes in panels for SD cards or connectors, etc. It is however very time consuming to make them. I query the position of each part in Kicad and type it into OpenSCAD, like this:
    Ethernet = ["Ethernet", "Duet Ethernet piggy back",
    33.8, 37.5, 1.6, 0, 2.54, 0, "#1D39AB", false, [[27.1, -6.3], [7.5, -2.7], [21.3, -31.1]],
    [[10.7, -13.1, 180, "rj45"],
    [7.75, -36.2, 0, "-2p54header", 6, 1],
    [7.75, -26.04, 0, "-2p54header", 6, 1],
    [27.1, -6.3, 0, "-standoff", 5, 4.5, 12.5, 2.54],
    [7.5, -2.70, 0, "-standoff", 5, 4.5, 12.5, 2.54],
    [21.3, -31.1, 0, "-standoff", 5, 4.5, 12.5, 2.54],
    DuetE = ["DuetE", "Duet 2 Ethernet electronics",
    123, 100, 1.6, 0, 4.2, 0, "#2140BE", false, [[-4, 4], [-4, -4], [4, -4],[4, 4]],
    [[ 18.5, -69.15, 0, "pcb", 5, Ethernet],
    [ 42.9, -3.2, 90, "molex_hdr", 4],
    [ 59.8, -3.2, 90, "molex_hdr", 4],
    [ 76.2, -3.2, 90, "molex_hdr", 4],
    [ 92.6, -3.2, 90, "molex_hdr", 4],
    [109.9, -3.2, 90, "molex_hdr", 4],
    [109.9, -9.6, 90, "molex_hdr", 4],
        [119.7, -31,     0, "molex_hdr", 3],
        [119.7, -88.6,   0, "molex_hdr", 2],
        [114.9, -75.1,   0, "gterm64",   2],
        [114.9, -43.5,   0, "gterm64",   2],
        [   39, -97,   -90, "molex_hdr", 4],
        [ 27.9, -97,   -90, "molex_hdr", 4],
        [ 83.7, -38.7, -90, "molex_hdr", 3],
        [ 74.3, -40.7, -90, "molex_hdr", 3],
        [ 64.0, -40.7, -90, "molex_hdr", 3],
        [ 54.0, -40.7, -90, "molex_hdr", 3],
        [ 44.1, -40.7, -90, "molex_hdr", 3],
        [ 35.0, -40.7, -90, "molex_hdr", 2],
        [ 28.9, -40.7, -90, "molex_hdr", 2],
        [103.0, -48.8, -90, "molex_hdr", 2],
        [ 97.0, -48.8, -90, "molex_hdr", 2],
        [ 90.3, -48.8, -90, "molex_hdr", 2],
        [ 84.1, -48.8, -90, "molex_hdr", 2],
        [ 77.9, -48.8, -90, "molex_hdr", 2],
        [105.2, -54.9,  0, "2p54header", 2, 1],
        [ 98.4, -54.9,  0, "2p54header", 2, 1],
        [ 90.2, -54.9,  0, "2p54header", 3, 1],
        [ 61.7, -83.1,  0, "2p54header", 5, 2],
        [ 29.5, -3.6,   90, "gterm35", 4],
        [ 45.0, -70.8,  45, "chip", 19, 19, 1.5],
        [ 34.6, -18.8,   0, "chip", 10, 10, 2],
        [ 53.2, -18.8,   0, "chip", 10, 10, 2],
        [ 71.8, -18.8,   0, "chip", 10, 10, 2],
        [ 90.4, -18.8,   0, "chip", 10, 10, 2],
        [109.9, -22.0,   0, "chip", 10, 10, 2],
        [105.8, -86.3,   0, "2p54boxhdr", 5, 2],
        [ 85.2, -86.3,   0, "2p54boxhdr", 5, 2],
        [ 79.9, -95.7, 180, "2p54boxhdr", 25, 2],
        [  2.0, -47.3, 180, "usb_uA"],
        [  8.4, -63.3, 180, "uSD", [15, 14.5, 2]],
        [  2.2,  -9.7,   0, "chip", inch(0.03), inch(0.06), 1, "red"],             // E1 heater
        [  2.2, -13.2,   0, "chip", inch(0.03), inch(0.06), 1, "red"],             // E0 heater
        [  2.2, -16.7,   0, "chip", inch(0.03), inch(0.06), 1, "blue"],            // Vin
        [  2.2, -20.2,   0, "chip", inch(0.03), inch(0.06), 1, "red"],             // 5V
        [  2.2, -24.0,   0, "chip", inch(0.03), inch(0.06), 1, "green"],           // 3.3V
        [  1.8, -41.8,  90, "chip", inch(0.03), inch(0.06), 1, "red"],             // USB
        [  2.3, -53.5,   0, "chip", inch(0.03), inch(0.06), 1, "red"],             // Diag
        [ 49.8,  -2.0,  90, "chip", inch(0.03), inch(0.06), 1, "red"],             // E1 stop
        [ 52.9,  -2.0,  90, "chip", inch(0.03), inch(0.06), 1, "red"],             // E0 stop
        [ 68.8,  -2.4,  90, "chip", inch(0.03), inch(0.06), 1, "red"],             // X stop
        [ 85.4,  -2.4,  90, "chip", inch(0.03), inch(0.06), 1, "red"],             // Y stop
        [101.6,  -1.8,  90, "chip", inch(0.03), inch(0.06), 1, "red"],             // Z stop
        [109.8, -58.8,   0, "chip", inch(0.03), inch(0.06), 1, "red"],             // Bed heater
        [ 2.3,  -37.2,   0, "chip", 3.6, 4.8, 2.0, "silver"],  // Reset switch
        [ 0.0,  -37.2,   0, "chip", 2.0, 2.6, 1.4, grey20],    // Reset button
        [": Micro SD card", ": Cat 5 patch cable 300mm"]];
  • you could export all components as individual STL.
    Onshape for example allows that, and since all STL-s will have the same origins you wouldn't need to set is position in openscad. Only you would need to color them individually.
    This is how I make it:
    1. Import STEP into Onshape
    2. Export all parts as individual STL-s
    3. Import all STL-s in openscad and set the colors, all files are packed into a module so I can move them around as one part.
