    Polar bed homing.
    polar printer
    • CNCModellerundefined
      CNCModeller
      Hi all.
      My polar build is almost ready for the electronics!
      Id like to be able to home the rotating bed to allow me to orient to print on a laser cut first layer, and also use the restart on power failure feature. As such I will need a bed rotation home switch.
      When the polar printer configuration was created what hardware was envisaged for the bed rotation home switch?
      I was thinking about a hall effect sensor but didn't know if it being triggered every rotation would be an issue?
      Also does bed mapping with a bltouch work on a polar printer? If so what is the maximum bed deviation it can allow for? My bed is 600mm dia sheet aluminium and it has enough warp to be an issue. I will probably mount a sheet of glass on it after initial testing, but would like to dilo initial tests with pla on kapton tape.
      Any thoughts would be much appreciated.
      Many thanks
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      • bondusundefined
        bondus
        It will work fine to home the polar bed, triggering while printing doesn't do anything.
        You could use an optical fork-style endstop mounted on the frame with a flag on the bed. They are cheap and work very well (unless you are in direct sunlight).
        You might have to edit homeall.g and make a homebed.g to move the bed to home.
        Add something like:
        G1 S1 Y-360 F1000 ; Rotate counterclockwise, up to 360 degrees.
        G1 S2 Y2 F1000 ; go back a bit
        G1 S1 Y-4 F120 ; approach slowly
          dc42 administrators @CNCModeller
          @cncmodeller said in Polar bed homing.:
          As @bondus said.
          Yes, bed compensation should work.
            CNCModeller
            Thanks for the info. Hopefully I will be putting it all together this weekend.
            Many thanks
            Barry M
            Wanhao D4S: Duet2
            K40 Laser, Duet2
            Wanhao D5S
