    M906 and rated current for steppers
    1.1k
    • piperswundefined
      pipersw
      Newbie question about M906 and rated current steppers.
      I have a corexy with dual Z steppers with these specifications:
      NEMA 17
      Dimensions: 42.3x42.3x48mm
      Bipolar
      Voltage: 2,8 V
      step: 200
      angle: 1,8° (+/-5%)
      holding torque: 50N.cm
      Resistance/phase: 1,65 Ohm per phase
      Inductance/phase: 2,8 mH per phase
      Current/phase: 1,68 A per phase
      For the BMG extruder:
      NEMA 17
      Dimensions: 42.3x42.3x25mm
      Bipolar
      Voltage: 2,7 V
      step: 400
      angle: 0.9°
      Resistance/phase: N/A
      Inductance/phase: N/A
      Current/phase: 1,4 A per phase
      Should I have to put the rated current or 85% of rated current for all motor ?
      M906 X1700 Y1700 Z1700 E1400 I30
      or
      M906 X1300 Y1300 Z1300 E1200 I30
      the motor mounts are in ABS, with 50° max internal enclosure temperature
      thx
        Here's what I do.
        I use M906 to set the full rated current for the motor, and then I use M913 to set the current to my desired percentage. https://duet3d.dozuki.com/Wiki/Gcode#Section_M913_Set_motor_percentage_of_normal_current
        That way when I use M913 I know that I'm getting the actual percentage that I set, rather than a percentage of a percentage that you'd get if you set M906 to 85% of the rated current to begin with. Make sense?
        For example:
        M906 X2000 Y2000 Z2000 E1400 I15 ; Set motor max currents (mA) and motor idle factor in per cent
        M913 X75 Y75 Z75 E80	 set X Y Z E motors to % of their max current
        dc42undefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @Phaedrux
          @phaedrux said in M906 and rated current for steppers:
          Here's what I do.
          For example:
          The snag with doing that is that if you use M913 to reduce current e.g. while homing, you need to know what M913 value to set it back to afterwards. Whereas if you use M906 to set the current you normally want to use (typically between 60% and 85% of rated current), then if you do use M913 to reduce current temporarily, you know that you have to restore it to 100%.
          Phaedruxundefined 1 Reply Last reply Reply Quote 1
            Phaedrux Moderator @dc42
            @dc42 Just to complete the loop, I actually have a few small macros that set the M913 current for different scenarios and are called as needed and I only have a single place to change the actual values.
            MotorCurrentsHoming.g
            MotorCurrentsPrinting.g
            MotorCurrentsDefault.g
            They just contain a M913 command.
            Exerqtorundefined 1 Reply Last reply Reply Quote 1
            • Exerqtorundefined
              Exerqtor @Phaedrux
              @Phaedrux said in M906 and rated current for steppers:
              A little late to the party, but i'm setting up to do the same as you atm, and i'm curious what percentages you are using in homing, printing & default?
                Phaedrux Moderator @Exerqtor
                @Exerqtor
                ; 0:/sys/CurrentsHoming.g
                ; Used to set motor currents for homing
                M913 X40 Y40 Z55
                ; 0:/sys/CurrentsNormal.g
                ; Used to set normal motor current
                ; Make sure these values match those in config.g
                M913 X75 Y75 Z75 E75
                ; 0:/sys/CurrentsPrint.g
                M913 X85 Y85 Z85 E85
                The percentage that you use for homing will depend on how much current you need to still have reliable movement without stalling/binding. It may also help to reduce acceleration and jerk during homing for the same reason.
