    Trigger Height and a lot of confusions
    953
    • Nielsundefined
      Niels
      Hello everybody,
      I'll go crazy....
      i have a delta printer with haydn magball arms, ethernet and a smarteffector.
      ii set the trigger height exactly as it is described in the wiki.
      It does not work: /
      after a change of the carriage adapters I do not get it back ... before it worked.
      I exclude the adapter. that's not it.
      When I restart the printer (with saved height as from the wiki) I do a g28, g32.
      then I drive to Z0 and he rams me into bed.
      A G30 s-1 tells me "stopped at 0.7"
      Where is my thought error?
      My Configs are in my Pastebin:
      https://pastebin.com/u/NealzE
      • Johncoffeeundefined
        Johncoffee
        This post is deleted!
          I assume you're talking about this process?
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
          The response logged in the console when doing G30 S-1 should be correct if you're following those procedures.
          Nielsundefined 1 Reply Last reply Reply Quote 0
          • Nielsundefined
            Niels @Phaedrux
            @phaedrux should it be stopped @ 0?
              Well not necessarily. It should stop at the trigger height.
              For nozzle contact probes that would be at 0 or slightly negative as it presses into the bed a bit. For proves that have a switch of some kind mounted above and to the side of the nozzle it would be some positive value.
              • Nielsundefined
                Niels @Phaedrux
                @phaedrux BUT when i drive to z=0 after g32 i should above the bed?
                That isnt working
                It drives IN the bed 😕
                • Nielsundefined
                  Niels
                  state:
                  M665 R225.5 L450 B185 H410.500
                  M558 P8 R0.4 H5 F1200 T6000
                  G31 P100 X0 Y0 Z0
                  Nozzle 210°
                  Bed 60°
                  • Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this.
                    -> Done. works. Bed stopped after g30
                  • Use the X and Y jog buttons to position the nozzle over the centre of the bed
                    -> Done x0 Y0
                  • Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
                    -> paper scratched @ Z 1.84
                  • Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                    -> Done ... Z=0
                  • Jog the head up by 5 to 10mm
                    -> Done M120
                    G91
                    G1 Z5 F6000
                    M121
                  • Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported.
                    -> G30 S-1
                    Stopped at height -0.029 mm
                    Z=-0.03
                  • Repeat from step 5 two or three times to make sure that the trigger height is consistent.
                    -> -0.022 -0.029 -0.022 -0.029
                  • In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
                    -> G31 P100 X0 Y0 Z-0.025
                    saved
                  • Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.
                    -> done . Only PID tuning Stuff in the override
                  • To apply the new trigger height, restart the Duet by sending M999 or pressing Emergency Stop.
                    -> Restarted
                  After All:
                  • G32 (look at pastebin)
                  • After that it stops at Z=5
                  • when i drive to Z=0 or start the print ---- the nozzle crashes in the bed.
                  G30 S-1 Stopped at height 0.797 mm
                  So annoying ... whats my mistake?
                  • Nielsundefined
                    Niels
                    After all:
                    When i do a G30 i got the correct height ....
                    Why does the g32 (bed.g) does not this?
                    • Nielsundefined
                      Niels
                      i realized that there are not compensation in use.... this is exactly what the g32 should to right?
                        Phaedrux Moderator @Niels
                        @niels g32 will only run the commands in bed.g
                        Do enable the compensation there must be a g29 S1 at some point to load the saved heightmap or G29 to run a probing cycle.
                        Usually best put in the slicer start gcode. Or at the end of bed.g which ever makes best sense.
                        • Nielsundefined
                          Niels
                          Yes. i know ..
                          in my bed.g i do alot of g30 and the last one with s6.
                          --> fail
                          when i do a single s30.. it sets the height correctly....
                          this is what i didnt understand
                          • Nielsundefined
                            Niels
                              Being that this is on a delta all I can recommend is to recheck your calibration routine. Not my area of expertise unfortunately.
                                Try running G32 twice after power up before you drive to Z=0. If the M665 parameters in config.g are a long way from the true values, then there can still be a height error after running G32 once. This is especially true in firmware 2.03, and there will be a 2.03.1 release to fix this.
