    Duet WiFi firmware bundle 1.15rc3 available for testing
    Firmware installation
    11
    30
    5.3k
      Hi Phil, that just the means that your heater is rather powerful and you need to use a lower pwm for tuning purposes. This won't affect the maximum pwm used in operation.
      • Aussiephilundefined
        Aussiephil
        @dc42:
        Ta David,
        Replied to the other thread as well, right at the moment trying at p0.2, will update other thread with results.
        Hopefully this can be a guide for others with high power heaters.
        Cheers
        PS: all the other bits/updates seem fine.
        Cheers
        Phil
          @RCarlyle:
          PanelDue has stopped talking to the Duet or responding to button touches… huh.
          I have just had this a couple of times. In both cases, one of the extruder temperatures was showing as a very large number (too wide to display in the box), and the other was showing 'ovf'. Both times, pressing the Reset button on the PanelDue restored normal operation.
          I conclude that the new firmware sent PanelDue some data that it choked on, although not badly enough to trigger the watchdog. I will try to find out what.
            I am about to release firmware version 1.15, which I will announce in a new thread. This fixes issues with starting up the temperature control system, which could lead to a heater going into the fault state and/or PanelDue freezing. Please continue discussions regarding heater tuning in the Heater Control thread.
            • ronnien58undefined
              ronnien58
              I am new to the Duet and would like to know if there are any issues using a mac with the duet wifi? Not a windows fan but if i have to have one i need to get something before mine arrives.
              • T3P3Tonyundefined
                T3P3Tony administrators
                While I don't personally use a Mac, Mhackney on the forum has used the pre-production board and the 0.8.5 successfully on Mac.
                His blog is here:
                http://sublimelayers.blogspot.co.uk/2016/01/bossac-script-and-bossac-for-mac-osx.html?m=1
                www.duet3d.com
                • curieosundefined
                  curieos
                  No issues here, just make sure you use chrome or firefox with the web interface.
                  She/Her
                  I work at a local 3D printing shop.
                  Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
                    ronnien58
                    Thanks, board arrives Tuesday, can't wait to get it installed and running.
                    • elmoretundefined
                      elmoret
                      @ronnien58:
                      I did all setup and actual use from
                      my MacbookPro. No problems at all. Your initial setup may vary a bit from the documentation (port naming, etc), but Windows is not necessary.
                        ronnien58
                        @elmoret:
                        @ronnien58:
                        Thanks, I will post when i am up and running.
