    12V PWM Fan on 24V Duet Wifi
    • Computigerundefined
      Computiger
      is it possible to use a 12V Fan on DuetWifi if main voltage is 24V?
      I have read an older topic and in that topic was described if I use 12V fans only I can take off the V-Fan Jumper and can connect +12V direct to the middle pin, is it right?
      • A Former User?
        A Former User
        in short; yes
        https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
          Computiger
          thanks 🙂
          • zaptaundefined
            zapta
            A three position connector similar to the other Duet connector (Molex KK) should fit well on that fan selection header.
