    Magically changing feed amounts
    1589
    • aparkin
      aparkin last edited by
      hi just sharing something that has happened to me while doing small prints my machine works fine (have done larger prints in the past just fine (not sure if i did them before are after last firmware update) but on large prints i.e over 3 hours
      so lager prints have been failing stats off fine then first 10mm of layers over a 250mm x 170mm print and my printer start to leave gaps like its partly jammed bottom of print perfect top of print crap gaps like its clogged ..so i have unclogged it change filament retry same thing again
      scratch head print smaller prints there fine go for a big one 17 hour print leave printer after 30 mins come back again bottom layer fine upper layers are crap total crap air holes everywhere
      and again i change filament change printer nozzle cheek for clogs nothing
      any and this over a two week period
      this time new filament new nozzle all oiled and primed smaller print 1 hour and it dose it again after about 40 mins anyway this time i pause print
      extruder is extruding so i pull the feed line apart make sure thats ok moves great decide to cheak feed amount as im running out of thing to look at and i push feed 100mm and i get 50mm (now this was set up and checked and double checked not delving my eyes i retried anther 4 times asked for 100mm but only got 50mm
      so i thought hmm OK ill reset the feed rate up turned off the machine had tea (yummy salmon and pasta bake)came back to a cold machine switch on switch me pc on getting read to reset up feed rate got my steal ruler out again remeasured my feed amount and nearly fell off my chair as i asked for 100mm and it feed me 100mm 5x in a row
      so now i thought maybe its matter hacker messing with it i use matter hacker to make my g codes which i use on my machine but i walked away and left the it on with filament in the printer so now i do have clog and i managed to kill my thermistor clearing the clog so no more testing tonight
      anyone had any thing similar to this happen
      things im going to try in order
      similar print using cura
      then update firmware ..then.. (complet wipe and install )
      • aparkin
        summary
        printer is changing feed rate as print start tested by using puase print
        and doing feed length checks
        start of print ask for 100mm and was given 100mm
        about an hour in ask for 100mm and was given 50mm ?
        now ive update firmware i was on 1.15c so about 6 mouth old
        and now using cura and not matter hacker encase it is gcode and there g code creator doing it ill get back to you and let you know if i get any change
          My guess is that it's a mechanical issue caused by the back pressure from the nozzle and the extruder stepper motor heating up, which will cause the filament to soften especially if you are using PLA. How hot does the extruder motor get after an hour of printing? What extruder design and what motor is it?
          • aparkin
            yes i am now thinking you may be on to something did the update and tried slic3r cura is pants its just my oppinun dont shoot me
            im using all metal Bowden Extruder out side of case i got a 1.7amp stepper motor running at 1.2amps
            and it seems i can now not feed 100mm thought my extruder (e3d v6) with out the motor jumping
            in case you want to see config file below
            ; Configuration file for Duet WiFi
            ; generated by RepRapFirmware Configuration Tool on Sat Nov 19 2016 12:24:27 GMT+0000 (GMT Standard Time)
            M111 S0 ; Debugging off
            G21 ; Work in millimetres
            M555 P5 ; Set firmware compatibility to look like Repetier
            M667 S1 ; Select CoreXY mode
            M208 X270 Y270 Z250 S0 ; Set axis maxima
            M574 X1 Y1 Z1 S0 ; Define active high microswitches
            M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
            G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
            M92 X79.5 Y79.5 Z400 E87.68 ; Set steps per mm
            M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
            M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
            M584 X0 Y1 Z2:4 E3
            M906 X800 Y800 Z800 E1200
            I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M143 S260 ; Set maximum heater temperature to 300C
            M305 P0 T100000 B4008 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
            M305 P1 T100000 B4008 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 1
            M563 P0 D0 H1 ; Define tool 0
            G10 P0 X0 Y0 ; Set tool 0 axis offsets
            M550 Pduetwifi ; Set machine name
            M551 Ptony ; Set password
            M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
            • aparkin
                It looks to me from the photo that you are using an un-geared extruder. Those typically need a long, high-torque Nema 17 motor run close to its maximum current to deliver enough force, especially when printing PLA. So try increasing the current to 1.5A or 1.6A.
                • aparkin
                  thanks for the tip ill look into geared bowden are better motor if you have found any you think are cool are work great please share
                  thanks for your help
                  • iDevelo
                    iDevelo last edited by
                    @aparkin:
                    If you have the cash http://shop.bondtech.se/ec/extruders/bondtech-qr-175-universal.html
                    • aparkin
                      Ouch thanks for the link but it will cost me and extra in import tax I'll stuck with UK stuff
                      Are print something out
                        @aparkin:
                        I recommend either the E3D Titan or the spring-loaded variation of the RapRap Ormerod extruder which is mostly printable. Both have a gear ratio of around 3:1.
                        • deckingman
                          deckingman last edited by
                          I can't really tell from the pics but another possibility is that whatever drives the filament is slipping on the motor shaft. It's a quick check to make sure that the grub screws are all tight.
                          A little tip - with a bit more aluminium extrusion you could mount the extruder above the bed, roughly in the centre which will reduce the length of your Bowden tube to less than half what you have now which will help in all sorts of ways.
                          • aparkin
                            Thanks for the tip
                            • aparkin
                              yep you was right it was maniacal i retro fitted an old wades extruder its running upside down and back to front but now it works like a charm so now to find that ormerod extruder
                              thanks for all the help
                              of course i can not shut the door but ill fix that soon
                              • aparkin
                                OK the problem is still persisting on long prints my printer fails a couple of hours in but small prints.look much beter
                                Is it worth putting a fan over the duet board
                                  If it's a Duet WiFi, then with the motor currents set as low as you have them it is most unlikely that you need to cool it with a fan.
                                  • aparkin
                                    Untested yet! just sermizsing.
                                    But I'll add a fan on board change the motor for one of the z motors
                                    I also get strange things happen when I have motor wire crossed over and I thought I got good ones for Germany….
                                    Never mind anyway I'll try all the above and make sure nothings come lose see if I can shorten my bowden tube
                                    And I'll get back to you let youknow how I get on
                                    p.s may take a few days
                                    Thanks for all the help
                                    • aparkin
                                      ok slight update not sure if this is related guess time will tell after a bit of head scratching wondering why nothing is working i found out i have a corrupt memory card pc is scanning and fixing is it worth retrying same card are just replacing it
                                      p.s so happy i copied my setting to an earlier post
                                      • aparkin
                                        hi all thanks for the help (dc42)
                                        ok problems
                                        memory card stopped working ( replaced card sorted )
                                        extruder getting hot and over extruding and under extruding and completely failing after 3 hours
                                        turned out i had my blue wire ad snapped inside the sheaf …....while cheeking and rerunning all the wire it fell in half in my hand strange
                                        its now 4 hours into a 6 hour print and back to normal
                                        p.s i got an extra motor in the post now
