    To use a non pwm fan for gcode control
    1
    390
    • Fickert
      Fickert last edited by
      So i am very confused oh how to hook up a 5v fan without pwm for gcode use to be controlled via the sliced print code.
      I had the fan hooked into the fan0 and system settings for fan0 as follows.
      M106 P0 S1 I0 F100 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      I can't get it to kick on with the m106 sxx command with range of 0-1 and ranges of 1-255 or by putting my hot end above 45C.
