    Adjusting servo speed
    • Arkadiusz
      Arkadiusz last edited by
      I assigned servo to unused fan I/O pins using M42 command, then I managed to move servo to desired position using M280.
      However servo is moving at its top speed. Is there any extra command that can be added to M280 in order to slow down the servo?
      Cheers
      zapta 1 Reply Last reply Reply Quote 0
      • zapta
        zapta @Arkadiusz last edited by zapta
        @arkadiusz, as a workaround, will it help splitting the move into multiple M280 and waiting for the completion of each step before moving to the next one?
        • Arkadiusz
          I was thinking about this solution, but I need to move servo with single macro button.
          I could pack macro with loads of individual M280 commands but I'm not sure how to set delay.
          • zapta
            @arkadiusz, does this help? https://duet3d.dozuki.com/Wiki/Gcode#Section_G4_Dwell
            (not discounting the original feature request of allowing to control the servo rate of change).
            • Arkadiusz
              I tried Dwell but its too "robotic", Its hard to achieve smooth movement. Looks like there is no such setup available on Duet at this moment. I ended making external servo controller using servo testers.
              Cheers
              • T3P3Tony
                T3P3Tony administrators @Arkadiusz last edited by T3P3Tony
                @Arkadiusz you can use dwell with the "P" parameter ans low as P1 for P1 millisecond do something like
                G4 P1
                M280 Pn S55
                G4 P1
                etc
                could work?
