Using Duet 3Mainboard with external stepper drivers
Yes.
But you can do this today. There are plenty of IO ports with outputs. These are 3.3V, but 3.3 V out to 5 V in logic almost always works.
You then trigger the camera with M42
@Danal said in Using Duet 3Mainboard with external stepper drivers:
Yes.
On the v1.0 Duet 3 main boards there is also the output marked Laser/VFD, which is 5V.
Any news about this?
For the moment there are not possibility of connect a external stepper/servo driver?It is the only thing that blocks me from buying Duet3, and I must continue buying Duet2 with expansion board.
And the Duet3 have important things that i want start to approach immediately.
Best Regards
Good orning, any news for this expansion board?
Because I use the duet 2 wifi for 2 external motor..
if even the duet 3 had the possibility to connect I would buy it immediately!
Thanks,
Andrea
@dc42 I am also interested in external drivers for Duet 3.
Any update on plans / schedule?
@nhof said in Using Duet 3Mainboard with external stepper drivers:
The prototype external stepper driver boards were ordered some time ago. They are taking a little longer than usual because both the assembly companies we use had to shut down temporarily in order to rearrange their production lines to facilitate social distancing, and even now are probably operating at reduced capacity. We should be getting them soon.
I am also wanting to use my duet 3 board for an application that uses hybrid stepper motor drivers. Unfortunately it looks like I will have to use the board on a project that has small enough motors for the onboard drivers until you make an expansion board.
If you want to use a Duet 3 but not wait for the expansion boards, then these https://www.chip45.com/products/sammy-c21-1.0_atmel_smart_arm_sam_module_board_samc21_usb_dual_two_can.php are likely to be an option soon. I already have the firmware build for them and I have a couple on order for testing.
Duet 3 external stepper driver prototype boards have arrived and passed all tests. https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_1XD
@dc42 Thats awesome!
when can we expect them to be available for purchase?
@dc42 Hello!
I'm very interested in variant with buffers for external drivers.
I'll help with PCB tracing and prototype testing if I have approved schematics in KiCAD.
