    IDEX printer: check my understanding of M584 (set drive map) command
    • mechw4rrior
      mechw4rrior last edited by
      I am commissioning a new cartesian IDEX printer powered by Duet WiFi and Duex5. It has:
      1 X axis motor
      1 U axis motor
      2 Y axis motors (these will always make the same moves, but mirrored)
      2 Z axis motors (these will always make the exact same moves)
      2 Extruder motors
      I would like to wire the motors as shown below:
      So according to my understanding of drive mapping, the drives should be mapped as follows:
      0: X axis
      1: Y axis primary
      2: Z axis primary
      3: E0
      4: E1
      5: U axis
      6: Y axis replica
      7: Z axis replica
      So finally my question is: Will the M584 command be written as below?:
      [c]M584 X0 U5 Y1:6 Z2:7 E3:4[/c]
      • T3P3Tony
        That looks correct.
        I am looking forward to pictures!
        Duet Hardware Designer
        www.duet3d.com
        • mechw4rrior
          Great! Thanks.
          Here's the start of the printer. It is mainly assembled from laser cut 1/8 inch thick 5052 aluminum (surprisingly affordable if you find a good supplier) and Misumi 2020 extrusion.
          It is still very early in the assembly phase, but I need to get a start at configuring the firmware to test the Z axis before I get too far along in assembly (made that mistake before and had to tear everything apart to solve binding).
