    I'm still seeing an undocumented error status code
    • grizewald
      grizewald last edited by
      All I've done since I powered on the machine is print a temperature test tower for a new filament and a small cube to verify an adjustment. As I'm about to start what might be a three day print, I'd really like to know what these errors mean. I don't want to waste all that time and filament!
      Here's the M122 I'm currently seeing:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F2MS4-7JTD0-3S86S-KYTND
      Used output buffers: 4 of 24 (10 max)
      Static ram: 25680
      Dynamic ram: 93716 of which 344 recycled
      Exception stack ram used: 540
      Never used ram: 10792
      Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,1668) IDLE(ready,160)
      Owned mutexes:
      Last reset 04:42:17 ago, cause: power up
      Last software reset at 2019-08-19 09:31, reason: User, spinning module GCodes, available RAM 10688 bytes (slot 0)
      Error status: 24
      Free file entries: 9
      SD card longest block write time: 391.7ms, max retries 0
      MCU temperature: min 25.8, current 34.2, max 40.3
      Supply voltage: min 23.9, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/146
      Driver 1: standstill, SG min/max 0/154
      Driver 2: standstill, SG min/max 0/48
      Driver 3: standstill, SG min/max 0/1023
      Driver 4: standstill, SG min/max 0/55
      Date/time: 2019-08-20 21:19:35
      Slowest loop: 139.09ms; fastest: 0.07ms
      Hiccups: 2, FreeDm: 169, MinFreeDm: 110, MaxWait: 3300406ms
      === DDARing ===
      Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 0 is on, I-accum = 0.1
      Heater 1 is on, I-accum = 0.5
      Segments left: 0
      Stack records: 3 allocated, 0 in use
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 392.82ms; fastest: 0.00ms
      Responder states: HTTP(3) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      -- WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address 84:f3:eb:42:a3:23
      WiFi Vcc 3.44, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 20864
      WiFi IP address 192.168.1.29
      WiFi signal strength -48dBm, reconnections 0, sleep mode modem
      Socket states: 2 4 0 0 0 0 0 0
      The secondary question is: If I simulate the file I'm about to print, will error status codes get conditioned by simulation?
      • NitroFreak
        NitroFreak last edited by
        what error exactly are you talking about? I can´t see anything special
          https://duet3d.dozuki.com/Wiki/Error_codes_and_software_reset_codes
          grizewald 1 Reply Last reply Reply Quote 0
          • grizewald
            grizewald @dc42 last edited by grizewald
            @dc42 said in I'm still seeing an undocumented error status code:
            Where on that page is the definition of this code: Error status: 24???
            0x04 is: Output buffer starvation
            0x20 is: ???????????????????????
            • A Former User
              A Former User last edited by
              It is a bitmask: 24 (decimal) = 1 1000
              So that's 2 error codes being set: 0x10 (16) and 0x08 (8).
                I'll change it to display the value in hex in the next release.
                • grizewald
                  D'oh!
                  My mistake, I assumed that as the codes were listed in hex, the value displayed would also be hex.
