    Does it matter if an axis is split over the Duet and a Duex?
    • grizewald
      grizewald last edited by
      I've decided to update my printer so that it uses three stepper motors to drive the Z axis and take full advantage of automatic bed levelling.
      Currently, my Z axis is driven by two steppers on the Z and E1 outputs on the Duet WiFi.
      Does it matter if the third Z motor goes on a Duex 5 output, or do I need to have all three motors driven from the same board?
        It doesn't matter. You just need to define which drivers belong to which axis. It would be typical to put all the Z axis on the expansion board just to keep them together and contiguous.
        grizewald 1 Reply Last reply Reply Quote 1
        • grizewald
          grizewald @Phaedrux last edited by
          @phaedrux said in Does it matter if an axis is split over the Duet and a Duex?:
          Thanks!
          If it's just a matter of whether I can cope with consecutive or non-consecutive numbers, then it's not an issue.
          I'm not sure yet how I'm going to put the two boards together and the wiring for the first two Z motors is already in place. While I might restructure a program to make sure that things are ordered in a coherent manner, I see no need to start lengthening wires unless I must.
