    Duet ethernet has no link
    • rb2602
      rb2602 last edited by
      I have the same problem as in post https://forum.duet3d.com/topic/5938/duet-ethernet-is-not-working
      When I plug in the ethernet cable, no led lights up on the ethernet board. The blue, green and red led on the system board are lit.
      The ethernet board is mounted correctly and I can connect to the Duet over the USB port.
      M552:
      Network is enabled, configured IP address: 192.168.0.177, actual IP address: 192.168.0.177
      M112:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-917DA-G4MS4-6J1DG-3S86L-98YBA
      Used output buffers: 1 of 24 (2 max)
      Static ram: 25680
      Dynamic ram: 93140 of which 0 recycled
      Exception stack ram used: 312
      Never used ram: 11940
      Tasks: NETWORK(ready,1972) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:00:35 ago, cause: reset button or watchdog
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11964 bytes (slot 2)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 32.8, current 33.5, max 33.8
      Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
      Cache data hit count 78590740
      Slowest loop: 0.95ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with “M122” in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.20ms; fastest: 0.02ms
      HTTP sessions: 0 of 8
      Interface state 2, link down
      ok
      • Dr_Ju_Ju
        Dr_Ju_Ju last edited by
        What is it plugged into ? a switch\hub or back to back computer ?
        Julian,
        Old goat, learning new things….
        • rb2602
          It is connected to a switch port.
            Have you tried a different cable, and a different port on your Ethernet switch?
            • Dr_Ju_Ju
              Make sure you aren't using a cross-over cable. Then try using some basic command line tools to test connectivity, i.e. can you ping the address you've set. If you get a response then try telnetting to the IP address \ port 80.
              Julian,
              • rb2602
                I am using a normal (not crossover) network cable on a working switch port. If I connect my Mac Book or a Windows PC with the same network cable to the same switch port, then everythin works. Both computers are connectoed to the network.
                If I connect the duet controller to the same switch port nothing happens. No link, no network connection.
                • T3P3Tony
                  T3P3Tony administrators @rb2602 last edited by
                  @rb2602 what if you connect the Duet to your notebook and use a fixed IP on the Duet and your laptop?
                  www.duet3d.com
