    Wrong size (solved)
    • KAMIKAZE_FREAKundefined
      KAMIKAZE_FREAK
      Tried printing a 200x210mm size print and the printer cut off corners
      have my Tronxy X5s set to 300X x 300Y but when i ask it to go to 300 x 300 it only goes to X205 and Y200.. if i ask it to go further... it wont do it..
      i tried looking in the files for 205 and 200 values but cant find anything.. and can find the max set to 300 x 300 x 400 like it should be...
      anyone have a explanation and a solution?
      Firmware Electronics: Duet Ethernet 1.02 or later
      Firmware Version: 2.03 (2019-06-13b2)
      Web Interface Version: 1.22.6
      E3v6 Clone
      BLTouch smart v2
        Check your M208 commands in config.g.
          KAMIKAZE_FREAK
          M208 X300 Y300 Z400 S0 ; Set axis maxima
          E3v6 Clone
          BLTouch smart v2
            KAMIKAZE_FREAK
            phaedrux found another m208 in config that overrided the previous settings.. deleted and now works properly
            E3v6 Clone
            BLTouch smart v2
            grizewaldundefined 1 Reply Last reply Reply Quote 0
            • grizewaldundefined
              grizewald @KAMIKAZE_FREAK
              @kamikaze_freak said in Wrong size (solved):
              Maybe English isn't your first language, but "overrode" is the correct tense here.
              (Tell me to ***** if you don't care one way or the other; I just have a problem with bad grammar.)
