    New RepRap config tool crashing my delta into carriage 3 endstop
    • USSCodyundefined
      USSCody
      after tweaking my config in the reprap configtool released yesterday upon homing the printer the printer just crashes into carriage three endstop (NC) over and over, has anyone else had any issues?
      • Danalundefined
        Danal
        The tool is a very general starting point, not a perfect config.
        Also, it is best practice to check endstops with your finger and ensure they show up as not-triggered and triggered (as appropriate) by issuing M119 commands. Home the machine only after that looks right.
        How are your endstops wired? Normally Open? Normally Closed?
        How are they configured? Something like this in config.g?
        M574 X2 Y2 Z2 S1 		; 2= Endstops at "top" of axis, S1= active high
        With the carriages away from the stops, M119 should return this, until you press a switch with your finger:
        M119
        Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
        Pressing a switch on a Delta results in:
        M119
        Endstops - X: at max stop, Y: not stopped, Z: not stopped, Z probe: not stopped
          dc42 administrators @USSCody
          @usscody said in New RepRap config tool crashing my delta into carriage 3 endstop:
          Is this a delta? If so, see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter?revisionid=HEAD#Section_Testing_the_motors_and_endstops_individually.
          • Shaunundefined
            Shaun
            New here, but noticed they removed the wifi config option from the configuration page. So you cant add the Sid and Password before exporting and copying to the SD card
            • T3P3Tonyundefined
              T3P3Tony administrators @Shaun
              @shaun said in New RepRap config tool crashing my delta into carriage 3 endstop:
              it was because it ended up being left in the config.g by users causing issues. its best to use the process describer here:
              https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s10
              to get on the wifi
              www.duet3d.com
