    Volumetric speed
    • peirof
      peirof last edited by
      I have see that Slicer 2 include volumetric speed...
      Exists some system for search volumetric speed of my printer
      • oliof
        oliof last edited by
        The maximum volumetric speed depends on your hotend and the material used. With PLA on a standard e3d v6 heatblock and 1.75mm filament on a .4 nozzle the maximum volumetric speed is 15mm^3/sec. A volcano hotend goes up to 25mm^3/sec.
        The prusa profiles for different materials have material specific volumetric maximums set, but they assume a standard setup such as above. So if you use the PLA profile you may need to tweak it for volcano hotends.
        When I looked into this I found http://projects.ttlexceeded.com/3dprinting_calibrating_volumetric_rate.html which may help you find out specific maxima for specific setups.
        You will reach maximum flow by setting really fast speeds for the different print speeds. Autospeed is quite buggy (doesn't work well with gap fill speed !=0 and gapfill speed 0 disables gap fill; depending on geometry features will print at weird slow speeds).
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
          This step of the ender 3 guide goes into finding the volumetric extrusion limit: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s177
          • peirof
            Thanks, very interesting
