    Wrong position after homing axes
    3.8k
    • CoolM8undefined
      CoolM8
      This is not what I'm looking for. I do not need to disable manual movement before homing and i do not need to overwrite that with manual commnands to move. All i want is G30 to work properly and not do to that strange additional movement that you can see in the video.
        Can you send G31 P1 in the gcode console? I suspect that the offset may not be applied correctly.
        Have you verified that the steps per mm is correct so that 10mm of requested movement equals 10mm of actual movement?
        @coolm8 said in Wrong position after homing axes:
        You can do as you wish, I'm merely explaining what's happening. Please keep in mind that we are only trying to volunteer our time to help you solve your problem. If you would prefer, I can stop trying to assist.
        • CoolM8undefined
          CoolM8
          I did not want to be rude. I just wanted to clarify what I'am trying to solve. Any help is welcome and I am thankful for all your support. Too sad it has not helped yet.
          G31 P1 does not do anything. Do I understand correctly that it should set the probe trigger value? Should the change be visible in the web view?
            In the gcode console, what does M558 return?
            Try sending
            M558 P1 H5 F120 T6000
            G31 P500 X40 Y0 Z0.35
            Then alter your homeall "first probe point" to move the probe to the center of the bed. Say G1 X100 Y100. Before the G30.
            and then test homing all.
            • CoolM8undefined
              CoolM8
              @phaedrux said in Wrong position after homing axes:
              Hmm, this is strange. Now it behaves completely different. The final position after G30 is now at X100 Y100 but the probed point which should be X100 Y100 is done at X0 Y100.
              As long is I do not execute G30 the axes are working correctly. Homing X and Y puts the head to left front corner, G1 X100 Y100 moves the head to the center. According to the documentation I have set the front left corner to be 0,0. Somehow after G30, X100 Y100 is 0,0.
                That definitely doesn't make sense. Are you sure you don't have any G92 commands in your homing files?
                • CoolM8undefined
                  CoolM8
                  No, I don't see any G92 commands in my homing files.
                    Could you upload your config files here? It would be helpful to see first hand everything that's going on. Slicer start gcode as well, since you stated it happens when starting a print, but otherwise works fine.
                    • CoolM8undefined
                      CoolM8
                      I haven't had time the last couple of time.
                      The problem happens not only when starting a print, but also when i execute homeall or home Z. Starting a print executes G30 first, homeall and home Z execute G30 at the ind.
                      I wonder why G30 is modifying my X Axis. I thought it should not do it when no Parameter is passed with it.
                      The config.g is not much different now, that what I have in the first post. Here it is:
                      M111 S1 ; Debugging off
                      G21 ; Work in millimetres
                      M564 H0 S0
                      M208 X180 Y180 Z205 S0 ; Set axis maxima
                      M669 K0
                      M574 X1 Y1 S0 ; Define active low and unused microswitches
                      M574 Z1 S2
                      M557 X0:180 Y15:180 S20 ; Define mesh grid
                      G31 P500 X40 Y0 Z0.35 ; Set Z probe trigger value, offset and trigger height
                      M350 X32 Y32 Z8 E16 I0 ; Configure microstepping without interpolation
                      M92 X157.4804 Y157.4804 Z533.3333 E832 ; Set steps per mm
                      M566 X1200 Y1200 Z480 E120 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X8100 Y8100 Z300 E1200 ; Set maximum speeds (mm/min)
                      M201 X500 Y500 Z100 E250 ; Set accelerations (mm/s^2)
                      M906 X1200 Y1200 Z1100 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M143 S290; Set maximum heater temperature to 310C
                      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                      ;M305 P1 R4700 T100000 B4388
                      M305 P1 X200
                      M563 P0 D0 H1 ; Define tool 0
                      M550 PUltimaker ; Set machine name
                      M552 S1 ; Enable network and acquire dynamic address via DHCP
                      M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      ;M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      ;M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        Phaedrux Moderator @CoolM8
                        ; Go to first bed probe point and home Z
                        G1 X0 Y15 F1800
                        Have you changed the position used to probe the bed as I suggested earlier?
                        If the Probe is +40 in X away from the nozzle, when you try and move the nozzle to X0, the probe would be at -40 in X over the edge of the bed. Get what I mean?
                        • CoolM8undefined
                          CoolM8
                          When i run G1 X0 Y15 F1800 before Z is homed it goes to the right position.
                          After G30 X0 it is actually 58mm away from real X0. With the current config I can move below 0 to X-58 until I hit the endstop.
                          It makes no difference if configured Probe to have an offset in X or not. G31 P500 X40 Y0 Z0.35 or G31 P500 X0 Y0 Z0.35 both configs bring the same result. I don't understand how the offset of 58mm is calculated.
                            Ideally you should position the probe so that it's in the center of the bed before sending G30 to probe. Have you tried changing your homeall to do that?
                            • CoolM8undefined
                              CoolM8
                              Yes, when my single probing point before G30 is the middle, the printer thinks it is the 0,0 position after G30. But when my single probing point before G30 is X0 Y15 the printer takes X58 Y15 as 0,0.
                                Do you think you could upload your config.g and homing files as they currently are?
                                The firmware will only do what it's told via gcode, so there is something somewhere that's telling it to do something that results in this current behaviour. Having it all in front of me at once makes it a lot easier to sort through.
                                • CoolM8undefined
                                  CoolM8
                                  I haven't found the time too look at it. Now I think I might have found something:
                                  When I home X and Y it works fine and when the endstops trigger, the print head stops immediately. But when when i manually control the print head movement or homing Z, the motors do not stop wen the endstop triggers. Therefore when homing Z moves to X0, it hits the endstop but it does not stop the motor. So I end up with an Offset in X.
                                  What I see is, the manual movement through WebControl sends this: G1 X-210 F1200.
                                  Homing sends this: G1 X-210 F1200 S1
                                  So the S1 parameter makes the edstops work. Now G30 must be using the move commands without S1.
                                  When I do the following change in config.g:
                                  M564 H0 S0 to M564 H0 S1
                                  Then, both G1 X-210 F1200 S1 works as does G1 X-210 F1200. That's because it limits the axis by calculation and not by the endstops anymore. However, G30 still hits the endstop but the motor keeps running for a short time as seen in the video here:
                                  https://youtu.be/9m7Y-PwS-pI
                                  How can I force G30 to make use of the axis limitation as well? Or can I somehow use the endstops all the time without using the calculated axes?
                                  • CoolM8undefined
                                    CoolM8
                                    When I move to X100 Y100 in homeZ and then call G30, why does G30 move anyway? In the documentations it says: "Probe the bed at the current XY position".
                                    HomeZ.g:
                                    ; Lift Z relatively to current position
                                    G91
                                    G1 Z5 F6000 S2
                                    ; Back to absolute positioning
                                    G90
                                    ; Go to first bed probe point and home the Z axis
                                    G1 X100 Y100 F6000
                                    G30
                                      @CoolM8 said in Wrong position after homing axes:
                                      This is as expected. The endstops are only acting when there is a homing move (G1 S1).
                                      G30 doesn't do any X or Y movement. You have to position the probe manually first. G30 will only move the Z axis.
                                      I don't know, I haven't seen your full config yet.
                                      • CoolM8undefined
                                        CoolM8
                                        This is my full config.g:
                                        M564 H0 S1
                                        M669 K0
                                        M574 Z1 S2
                                        M305 P1 X200
                                          And homing files?
                                          • Vetiundefined
                                            Veti
                                            M564 H0 S1
                                            i have pointed out to you earlier that this should not be in the config. why do you insist on having that in your config?
