    Need help to define Z max endstop
    1.4k
    • T3P3Tonyundefined
      T3P3Tony administrators @Olivier
      @olivier @veti S1/H1 are interchangable in G1
      www.duet3d.com
      • T3P3Tonyundefined
        T3P3Tony administrators @T3P3Tony
        @Olivier what does M119 show when you have the Z switch triggered?
        www.duet3d.com
        Olivierundefined 1 Reply Last reply Reply Quote 0
        • Olivierundefined
          Olivier @T3P3Tony
          @t3p3tony
          M119
          Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @Olivier
            @olivier
            issue the command
            M574 Z2 S0
            check M119 when the endstop is not triggerd
            hold endstop
            check M119 again
            • Olivierundefined
              Olivier @Veti
              @veti said in Need help to define Z max endstop:
              M574 Z2 S0
              14:12:13M119
              Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
              14:12:04M119
              Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
              14:11:58M574 Z2 S0
              • Olivierundefined
                Olivier
                My macro :
                M574 Z2 S0
                G1 Z300 F3000
                It was inverted so I put the command M574 Z2 S1 but it not stop anyway...
                • Vetiundefined
                  Veti
                  @olivier said in Need help to define Z max endstop:
                  There is no endstop command in your macro and it seems you need to invert the endstop
                  try
                  M574 Z2 S1
                  G1 Z300 F3000 H1
                  M574 Z1 S2
                  • Olivierundefined
                    Olivier
                    G1 Z300 F3000 H1
                    You're right !! it work now 🙂
                    Thanks a lot.
                    I will try the stall detection now
                    • Vetiundefined
                      Veti
                      i still dont understand what you want to achieve with this.
                      • Olivierundefined
                        Olivier
                        If I need to lower the bed without homing and without clicking several time on Z axis move
                        Stall detection works perfectly too 😉
