    Need help to define Z max endstop
    1.4k
    • Olivierundefined
      Olivier
      Hypercube evolution 🙂
      • Vetiundefined
        Veti
        what are you trying to achieve with the z max endstop?
          T3P3Tony administrators @Olivier
          @olivier Rather than using a switch, if you just want to lower the bed then send it to that specific position at the end of the print: G1 Zzzz Fnnnn
          You don't need a switch because the printer knows where Z is at the end of the print.
          • Olivierundefined
            Olivier
            Hi @T3P3Tony ,
            Yes but I would like to add a user macro "down the bed" without homing (for exemple after a power failure).
            Maybe it's possible with stall detection ?
              @olivier It may be possible with stall detection. but if you just want a macro and you have a switch then just write the macro to move and stop when the switch is sensed, wrap the movement in a line to configure that switch as the Z endstop and then configure it back to the probe after the movement has finished.
              • Olivierundefined
                Olivier
                I tryed to do that but without good result,
                Could you just write this 2 or 3 lines ? Thank you for your help.
                  @olivier If you determine the Z axis setting to use a switch at Z max (i think you have already done that) then the macro would be something like:
                  Z_Max_home.g macro in /macros/
                  M574 Z2 S0
                  G1 Z300 F<something sensible> H1
                  M574 <whatever you have in your config.g to setup for the BL touch>
                  Note i have not tried this so you will need to experiment a bit and have your hand on the power button as things move!
                  Olivierundefined 1 Reply Last reply Reply Quote 0
                  • Olivierundefined
                    Olivier @T3P3Tony
                    @t3p3tony said in Need help to define Z max endstop:
                    M574 Z2 S0
                    Bed going down but don't stop when I press the switch. The endstop LED react correctly
                    • Vetiundefined
                      Veti @Olivier
                      @olivier
                      add S1 to the G1 command
                      • Olivierundefined
                        Olivier @Veti
                        @veti It dont move at all with S1
                        • Vetiundefined
                          Veti
                          @olivier said in Need help to define Z max endstop:
                          M574 Z2 S0
                          try changing this to
                          M574 Z2 S1
                          • Olivierundefined
                            Olivier @Veti
                            @veti Same problem... 😞
                              @olivier @veti S1/H1 are interchangable in G1
                                T3P3Tony administrators @T3P3Tony
                                @Olivier what does M119 show when you have the Z switch triggered?
                                • Olivierundefined
                                  Olivier @T3P3Tony
                                  @t3p3tony
                                  M119
                                  Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                                  • Vetiundefined
                                    Veti @Olivier
                                    @olivier
                                    issue the command
                                    M574 Z2 S0
                                    check M119 when the endstop is not triggerd
                                    hold endstop
                                    check M119 again
                                    • Olivierundefined
                                      Olivier @Veti
                                      @veti said in Need help to define Z max endstop:
                                      M574 Z2 S0
                                      14:12:13M119
                                      Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
                                      14:12:04M119
                                      Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
                                      14:11:58M574 Z2 S0
                                      • Olivierundefined
                                        Olivier
                                        My macro :
                                        M574 Z2 S0
                                        G1 Z300 F3000
                                        M574 Z1 S2 ; Set endstops controlled by probe
                                        It was inverted so I put the command M574 Z2 S1 but it not stop anyway...
                                        • Vetiundefined
                                          Veti
                                          There is no endstop command in your macro and it seems you need to invert the endstop
                                          try
                                          M574 Z2 S1
                                          G1 Z300 F3000 H1
                                          M574 Z1 S2
                                          • Olivierundefined
                                            Olivier
                                            G1 Z300 F3000 H1
                                            You're right !! it work now 🙂
                                            Thanks a lot.
                                            I will try the stall detection now
