Z-Probe input signal
Hi all,
I'm fitted my cartesian printer with a small PINDA probe for the Z axis. Since the probe needs 5v I connected it to the 5v on the extension pins instead of the Z-Probe connector.
My question is however regarding the signal voltage. Since the PINDA works at 5v, it must return 5 volts also. Can I plug the signal cable from the PINDA directly to the board or do I have to add a diode like with the bigger capacitive/inductive sensors?
Thanks in advance,
FH
it depends on your duet version.
see
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe -
Duet Wifi 2, 1.04
the duet v1.04 endstop pins can tolerate higher voltage
so you can connect it directly as written in the guide -
@veti said in Z-Probe input signal:
so you can connect it directly as written in the guideThanks a lot. I read the link you sent me through, but it's a bit overwhelming, I must admit...
