    Deleting Gcode files on micro sd card
    • brian
      brian last edited by
      Is there anyway to delete gcode files on the sd card without removing the card from the duet?
      • A Former User
        A Former User last edited by
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M30_Delete_a_file_on_the_SD_card
        or use duet web control
        brian 2 Replies Last reply Reply Quote 0
        • brian
          brian @Guest last edited by
          @bearer Thx for the link. I havent found a way to delete from DWC
          • A Former User
            right click a file entry?
            (screenshot from dwc2)
            • brian
              @bearer OK found it, right click filename!
                dc42 administrators @brian last edited by
                @brian said in Deleting Gcode files on micro sd card:
                You can delete a bunch at once by checking the boxes next to them and right clicking on one of them.
                • zapta
                  zapta last edited by
                  Considering that gcode files are typically used as temporary local copies for the printing process, would be nice to be able to enable a global time to leave. E.g. delete gcode files that have not been used for 3 days.
