    Fan1 dont show
    775
    • TPJensenundefined
      TPJensen
      Hi
      I just made a firmware update 2.03 (2019-06-13b2)
      it looks good but I have 2 part coolers But only fan 0 show up and also Fan 0 is the only one there spin up.
      In firmware 1.20 beta6 I had all the fans on the web control panel... But I had to turn on fan1 manually but it work.
      What do I do to get it to turn on auto or get Fan1 slider back in web control panel
      My board is Duet 2 wifi
        Config.g please.
        TPJensenundefined 1 Reply Last reply Reply Quote 0
        • TPJensenundefined
          TPJensen @Phaedrux
          @phaedrux said in Fan1 dont show:
          Config.g please.
          ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
          ; Delta Settings
          M665 L440.000 R227 H456.0 B185.0 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
          M552 S1
          M550 P"Anycubic Predator" ; Set machine name
          M551 P"" ; Set password
          M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M92 X80.00 Y80.00 Z80.00 E380.45 ; Set steps per mm
          M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z12000.00 E10000 ; Set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; Set accelerations (mm/s^2)
          M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          ; Retraction
          M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction
          M208 Z0 S1 ; Set minimum Z
          M574 X2 Y2 Z2 S1 ; Set active high endstops
          M558 P4 H3 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z16.0 ; Set Z probe trigger value, offset and trigger height
          M557 R115 S20 ; Define mesh grid
          G29 S1 ; Load the heightmap
          M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
          M305 P0 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 1
          M143 H1 S250 ; Set temperature limit for heater 1 to 240C
          M563 P0 D0 H1 ; Define tool 0
          M572 D0 S0.1 ; Pressure Advance
          ;M591 D0 P2 C4 S1 ; Activate filament sensor
          M404 N1.75 ; Set for print monitor
          M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0
          Config.g please.
            Phaedrux Moderator @TPJensen
            @tpjensen said in Fan1 dont show:
            M106 P0 H-1 controls the Fan0 port and would be for your part cooling fan, which should show up in the DWC as a slider, and be controllable by the slicer in Gcode during a print.
            M106 P1 H1 T45 controls the Fan1 port and should be for your hotend fan, it is configured to turn on automatically when the temperature reaches 45c.
            https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
              Further, this command attaches the Fan0 port to your tool, which should make it controllable via the tool fan slider in the DWC.
              • TPJensenundefined
                TPJensen @Phaedrux
                I have 2 part cooler 1 hotend cooler
                Hotend cooler start when hotend is heated and then only 1 part part cooler turns on with the layer I set it to
                  If you have 2 part cooling fans, how are the connected to the board?
                  • TPJensenundefined
                    TPJensen @Phaedrux
                    @phaedrux
                    They are like this
                    Hotend fan on : Fan1
                    Part cooler Fan0 : Fan0
                    Part cooler Fan1: Fan2
                      Alright, so you need a M106 command for Fan port 2 similar to the one for fan port 0.
                      M106 P2 S0 I0 F500 H-1 ; Set fan 2
                      • TPJensenundefined
                        TPJensen @Phaedrux
                        Do I write that as a extra line ?
                          Yes. Add it below the other 2.
                          TPJensenundefined 2 Replies Last reply Reply Quote 0
                          • TPJensenundefined
                            TPJensen @Phaedrux
                            Done and it worked 😎 So now I will make the print again tommorow
                            Just one thing more how and where do I write M929 P"eventlog.txt" S1 ; start logging to file eventlog.txt
                            M929 S0 ; stop logging
                            • TPJensenundefined
                              TPJensen @Phaedrux
                              @phaedrux
                              And thank you so much for your help 🤝 👍
                                You could add the start to config.g and the stop to your slicer end gcode.
                                Though I question if at this point you actually need it. Logging can also have a negative impact on performance due to the overhead. Best not to use it unless you need it.
                                • TPJensenundefined
                                  TPJensen @Phaedrux
                                  @phaedrux
                                  I dont want to have the M929 running expect if it fails again with the hotend stops heating.
                                  So it is just to see what happens if I get more fails.
                                  • TPJensenundefined
                                    TPJensen @Phaedrux
                                    @phaedrux
                                    Okay update
                                    Maybe I have done some wires wrong... Both fans show up in web control and fan0 start on 3 layer like I told it to do i slicer but the other part cooler fan1 dont turn on unless I use the slider in control panel.
                                    Another problem is when fans turn on hot temp fall from 240 to about 230-232 with only the fan0 if I turn fan1 on same time I will get Heater 1 fail. Can it be something about the power to the hotend ?
                                    When fan0 turn on and I wait 1-2 min. and turn fan1 on slowly temp drops but no fail on hotend and after that temp is constand.
                                      Ah yes there is one more piece to the config missing. We need to add the extra fan to the tool definition.
                                      Should become
                                      M563 P0:2 D0 H1 ; Define tool 0
                                      That should attach fan0 and fan2 to tool 0
                                        To solve the fans cooling the hotend too much you'll have to aim the fans more carefully so they aren't blowing on the heater block.
                                        You can also use a silicone heater block sock to cover it and shield it from the cool air.
                                        And you can also run the PID tuning with the fans running at your regular print speed so that the model can account for the extra cooling of the block.
                                        • TPJensenundefined
                                          TPJensen @Phaedrux
                                          Should become
                                          Super thank you so much, I'am glad your want to help
                                          • TPJensenundefined
                                            TPJensen @Phaedrux
                                            I have made a order now on silicone socks
