    PID Tuning Number of Cycles
    2.2k
    • GeorgeMundefined
      GeorgeM @T3P3Tony
      @T3P3Tony Ok, I'm back at it again. It looks like things have gotten confusing so I would like to step back and iterate what my setup is.
      My printer is a BLV Cube build ala https://www.thingiverse.com/thing:3382718
      Equipment is:
      24v power supply
      Duet 2 WiFi
      Zesty Nimble extruder
      Genuine E3D V6 All Metal Hotend with 24v heater (measures 14.4 on resistance)
      Tests conducted with silicone sock on and parts fan on.
      First test with PWM at 1
      8:07:05 AMM307 H1
      Heater 1 model: gain 549.0, time constant 262.4, dead time 8.0, max PWM 1.00, calibration voltage 23.7, mode PID, inverted no, frequency default
      Computed PID parameters for setpoint change: P10.7, I0.234, D59.7
      Computed PID parameters for load change: P10.
      8:04:31 AMWarning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 573C.
      Auto tune heater 1 completed in 395 sec
      Use M307 H1 to see the result, or M500 to save the result in config-override.g
      8:00:29 AMAuto tune phase 3, peak temperature was 259.6
      8:00:21 AMAuto tune phase 2, heater off
      7:58:01 AMAuto tune phase 1, heater on
      7:57:55 AMM303 H1 S250 P1
      Second test with PWM at .8
      Heater 1 model: gain 285.7, time constant 172.4, dead time 3.9, max PWM 0.80, calibration voltage 23.8, mode PID, inverted no, frequency default
      Computed PID parameters for setpoint change: P27.6, I1.066, D75.4
      Computed PID parameters for load change: P27.
      8:44:00 AMAuto tune heater 1 completed in 447 sec
      8:41:22 AMAuto tune phase 3, peak temperature was 252.6
      8:41:18 AMAuto tune phase 2, heater off
      8:36:38 AMAuto tune phase 1, heater on
      8:36:33 AMM303 H1 S250 P0.8
      Auto tuning heater 1 using target temperature 250.0°C and PWM 0.80 - do not leave printer unattended
      Third test with PWM at .7
      eater 1 model: gain 234.7, time constant 160.1, dead time 6.4, max PWM 0.70, calibration voltage 23.7, mode PID, inverted no, frequency default
      Computed PID parameters for setpoint change: P19.0, I0.595, D85.2
      Computed PID parameters for load change: P19.
      9:01:38 AMM307
      9:01:12 AMM307
      8:59:27 AMAuto tune heater 1 completed in 573 sec
      8:56:59 AMAuto tune phase 3, peak temperature was 251.0
      8:56:55 AMAuto tune phase 2, heater off
      8:49:59 AMAuto tune phase 1, heater on
      8:49:53 AMM303 H1 S250 P0.7
      Auto tuning heater 1 using target temperature 250.0°C and PWM 0.70 - do not leave printer unattended
      Only after running with the results of PWM 0.7 was the temperature stable. Others showed continuous fluctuations.
      Results of each test were saved with M500.
      Results are saved in config-override.g
      Nothing is saved in config.g
      M501 is called out at end of config.g
      Here is config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Aug 14 2019 07:35:06 GMT-0600 (Mountain Daylight Time)
      M667 S1 ; Select CoreXY mode
      M550 P"BLV Cube" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 X goes backwards
      M569 P1 S0 ; Drive 1 Y goes backwards
      M569 P2 S0 ; Drive 2 Z goes backwards
      M569 P3 S1 ; Drive 3 E1 goes forward
      M569 P4 S0 ; Drive 4 U goes backward
      M92 X100.54 Y100.54 Z400.21 U400.21 E2892.00 ; Set steps per mm
      M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
      M350 E16 I0 ; Configure microstepping witout inerpolation
      M566 X400.00 Y400.00 Z100.00 U100 E80.00 ; Set maximum instantaneous speed changes (mm/min) was 480 for x and y
      M203 X10000.00 Y10000.00 Z6000.00 U6000.00 E8000.00 ; Set maximum speeds (mm/min)
      M201 X600.00 Y600.00 Z30.00 U30.00 E100.00 ; Set accelerations (mm/s^2) was 800 for x and y
      M906 X1200.00 Y1200.00 Z800.00 U800.00 E500.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M584 X0 Y1 Z2:4 ; two Z motors connected to driver outputs Z and E1
      M671 X-20:310 Y0:0 S2 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X-5:305 Y0:300 ; X carriage moves from -5 to 305, Y bed goes from 0 to 300
      M84 S30 ; Set idle timeout
      M208 X-25 Y-30 Z0 S1 ; Set axis minima
      M208 X300 Y300 Z300 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 S.02 T7000 ; Set Z probe type to bltouch and the dive height + speeds
      ;M558 P9 H5 F120 T7000
      G31 P500 X30 Y-10 Z1.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:285 Y10:275 P4 ; Define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4725 C7.06e-8 ; Set thermistor + ADC parameters for heater 1
      M106 P1 S0 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      Here is config-override.g
      ; config-override.g file generated in response to M500 at 2019-09-09 09:02
      ; Heater model parameters
      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
      M307 H1 A234.7 C160.1 D6.4 S0.70 V23.7 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      • T3P3Tonyundefined
        T3P3Tony administrators
        @GeorgeM thanks - that setup should work without reducing PWM. When @dc42 gets a chance maybe he can add to this.
        BTW -its not related but you should not have M587 in your config.g
        www.duet3d.com
        GeorgeMundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • GeorgeMundefined
          GeorgeM @T3P3Tony
          @T3P3Tony Thanks, I missed that.
            dc42 administrators @T3P3Tony
            @t3p3tony said in PID Tuning Number of Cycles:
            Yes, that should work. If you send M307 H0 from the GCode console, it should show that it is using the heater 0 parameters that were saved to config-override.g. Similarly for M307 H1.
            • T3P3Tonyundefined
              T3P3Tony administrators @dc42
              @dc42 that part is working. the issue is the oscillation with the results from M303 with a PWM value of >0.7
              @GeorgeM it would be helpful if you could post some images of the temperature graph to show this oscillation at PWM 1 and 0.7
              www.duet3d.com
                If the temperature oscillates, that normally means that tuning has under-measured the M307 D parameter. It can be fixed by increasing the D parameter. Try a 50% increase.
                • GeorgeMundefined
                  GeorgeM
                  Well, just like going to the auto mechanic, today I disasembled the hotend, cleaned it up, put it back together and redid the PID with PWM of 1. I still got the error of overheating but in doing my first test print the temp seams stable. Only oscillating about .5d.
                    Phaedrux Moderator @GeorgeM
                    @GeorgeM The overheating warning won't go away. It's meant to inform you of the predicted possible max temps reachable in a fail on situation. In other words, keep an eye on your printer.
                    GeorgeMundefined 1 Reply Last reply Reply Quote 0
                    • GeorgeMundefined
                      GeorgeM @Phaedrux
                      @Phaedrux Second day and it's still holding pretty steady so good to go.
                      Thanks for all you input.
