    BlTouch not triggering/deploying/led not turning on
    3.2k
    • 3DGoatundefined
      3DGoat
      I have had the duet wifi running with the BlTouch for about 3 months now, I recently redid the wiring (for a cable chain) and the probe no longer is working. I bought a genuine Bltouch from their official website. I turn on my Duet wifi and the LED does not light up or self test. I have tested all the wiring with a multi meter, and they all seem to be working. I am running the Bltouch at 5v off the duet 2 wifi. What am I missing? alt text (There is an extention for the wires, From bltouch to duet Brown=Blue, Red=Red, Orange=green)
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Jul 03 2019 20:24:43 GMT-0500 (Central Daylight Time)
      M550 P"BenchBot" ; Set machine name
      M552 S1 ; Enable network
      M587 S"ATT-HOMEBASE-4847" P"23192130" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Physical drive 0 goes forwards
      M569 P1 S1 ; Physical drive 1 goes forwards
      M569 P2 S1 ; Physical drive 2 goes forwards
      M569 P3 S1 ; Physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z400.00 E96.2 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X150.00 Y300.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X1500.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M584 X0:4 ; Configure dual X with X and E1
      M208 X720 Y330 Z400 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      ;Z probe
      M307 H3 A-1 C-1 D-1
      M558 P9 H5 F100 T2000
      G31 X0 Y0 Z0 P25
      M140 H-1 ; Disable heated bed
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S260 ; Set temperature limit for heater 1 to 260C
      M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      • 3DGoatundefined
        3DGoat
        Photo: https://ibb.co/h9TZMvF
        • PaulHewundefined
          PaulHew
          Another user had the same issue just the other day. Turned out to be a break in the cable when it was bent.
          Does the BL do its self test when powered up?
          Is it 'red' solid or 'red flashing' or no lights on it at all?
          RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
          Voron 2.4 disassembled..... Waiting for the RailCore Mini....
          3DGoatundefined 1 Reply Last reply Reply Quote 0
            90% of the time it's a cabling issue.
            If possible, test the BLTouch connected directly to the board with very short cables to verify it's working at all. Triple check that you're connecting to the right pins.
            Config looks ok provided you're connecting to heater pin 3 on the expansion header.
            If it's not lighting up at all that would indicate the power lead is not connected, or the probe itself is dead.
            • 3DGoatundefined
              3DGoat @PaulHew
              @paulhew No lights at all
              • 3DGoatundefined
                3DGoat @Phaedrux
                @phaedrux I just tried the shorter cable thing, It still does not turn on or self test.
                • fcwiltundefined
                  fcwilt @3DGoat
                  @3dgoat said in BlTouch not triggering/deploying/led not turning on:
                  Do you have a Duex2 or Duex5 connected to your Duet WiFi?
                  • 3DGoatundefined
                    3DGoat @fcwilt
                    @fcwilt I do not have the duex connected to my controller
                    • PaulHewundefined
                      PaulHew
                      Please post a picture of the other connector the BL Touch uses, it is by the panel due connector.
                      Also check the tiny connector on the back of the BL, as that has caught me out before. Carefully unplug and plug it back in.
                      HTH
                      Paul
